![]() | Home > For Sale & Wanted > [For Sale] Reduced Defender Steels with tyres and nuts |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I have a set of five steel wheels and tyres from our 110. The rims are in good condition, one of them is worse than the others, but this was the spare.
Tyres all have plenty of life left (I will measure the tread depths tonight) and are 7.50R16 goodyear wranglers. Had them all balanced about a month before I removed them. Also come with a set of 20 steel wheel nuts. £175 or offers, collected from near Rotherham or could take to LRO Ripley Castle show in May. Steve Pics to follow.... 02' 110 TD5 Double Cab Rebuild Thread Last edited by rallysteve on 22nd May 2015 5:42pm. Edited 1 time in total |
Steve,
Worth a punt perhaps if he will consider steels to retain his alloys.....? http://www.defender2.net/forum/topic36762....=deep+dish ![]() Treat every day as if it is your last....one day you will be right!! |
Cheers, will send him a PM although he is a little far away!
will check but I thought wolf wheels had more offset.
Will let you know. Cheers[/quote] 02' 110 TD5 Double Cab Rebuild Thread |
Offset as stamped on them is 33mm how ever that compares to wolf wheels?!
Hope that is of some use? Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
HI Steve - I think it has to specify 6J - stamped somewhere on the wheel? If not then they will not fit my needs and I would have to withdraw my 'dib'.
I am after some wheels with this offset as I am fitting a Zeus disc conversion on my Series One, and the wheels need to clear the callipers. Euro-Leafing to infinity and beyond..... |
As I say it is stamped 33mm offset on the wheels which I think is -33mm. I believe wolf wheels are -22mm. so 11mm more offset and and inch wider.
I can't really see how the offset affects the caliper clearance however. Steve 02' 110 TD5 Double Cab Rebuild Thread |
6j refers to width (usually) so 6inch wide, offset is usually followed by et so 33et or 22et Ray
Bump still available, Reduced to £160
![]() Will be at Ripley Castle LRO Spring Adventure on Saturday Steve 02' 110 TD5 Double Cab Rebuild Thread |
One day offer to £120 to anyone going to Ripley show on saturday!
Sold 02' 110 TD5 Double Cab Rebuild Thread
