Home > In Car Electronics > DC to DC battery chargers
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I am looking at this http://www.ringautomotive.co.uk/uk/product...-/RSCDC30# as an alternative to fitting a split charging system, as I want to be able to swap it between vehicles. Has anyone got any experience of such devices at all? Euro-Leafing to infinity and beyond.....
Post #418484 23rd Apr 2015 9:11pm
munch90
How many vehicles do you want to swap between ?
Post #418485 23rd Apr 2015 9:15pm
strang
Just two - and yes, I guess two separate split charge systems will cost the same or less! - but I would be swapping a leisure battery between vehicles too.
However, one vehicle would be my series one (which has an alternator) so I wasn't sure if a full split charge system would fit. Euro-Leafing to infinity and beyond.....
Post #418691 24th Apr 2015 3:53pm
munch90
think you mean series 1 has a dynamo and yes voltage from that could be a problem
the small split charge (think they 20amp) units from smartcom have a adjuster for voltage cut in , the smartcom is what they fit for caravan battery charging ( don't know if they are suitable or not for dynamo )
think I would go down the route of 2X split chargers ,2x small Anderson plugs , and battery in a box ( box should be vented to outside of vehicle )
or 1x split charger built in to leisure battery box then just plug into each vehicle via small Anderson plug for charging
whats leisure battery for ?
TROUBLE WITH CHARGING ANY BATTERY INSIDE THE VEHICLE THE BATTERY SHOULD BY IN A PROPER BATTERY BOX AND BE VENTED OUTSIDE
Post #418695 24th Apr 2015 4:13pm
strang
Thanks for the info - my Series One does have an alternator as its fitted with a 200Tdi (not for the purists!) so volts aren't a problem.
The leisure battery is for powering an ARB fridge when parked up on a camp site (I go on long trips abroad with both my Defender and the series one).
I have previously asked about some kind of 'portable' split charging system, and that might well work with Anderson connectors. I never though of that. Sounds like a solution and a good idea - thanks (cheaper too)
How easy would it be to do if I bought a kit such as this - http://www.ebay.co.uk/itm/261610607268?_tr...EBIDX%3AIT Euro-Leafing to infinity and beyond.....
Post #418698 24th Apr 2015 4:23pm
munch90
ah ok if alternator then all should be ok
ive just fitted one of the durite split charger, all works ok
personally I would put split charger outside of the portable battery box , just in case ( you don't want any sparks in with a charging battery in case its gassing at all )
Post #418708 24th Apr 2015 4:43pm
strang
Cheers for the info Euro-Leafing to infinity and beyond.....
Post #419235 26th Apr 2015 6:55pm
