![]() | Home > Maintenance & Modifications > Mantec roof bars making a racket 😮 |
Try moving the position of the front bar and see if that improves the noise.
Brendan |
Boris Member Since: 02 May 2014 Location: Oswestry Posts: 21 ![]() ![]() ![]() |
Thanks Brendan , I'll give it a whirl , it's right at the front at the moment , so will try moving it 8" back and give it a try
If it is right at the front then I could imagine air hitting the windscreen divert upwards hitting your Manbo bar causing the noise.
It might take a couple of attempts to get it right. Brendan |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20842 ![]() ![]() |
I've got two on mine, might be the Snorkel causing a different airflow party as I don't have one.
But no noise from mine! The front one is located just above the frontal first section of flat roof. So above that section but just behind the seam of the sloping section heading down to the windscreen. If that makes sense? |
Cheers Steve
I've moved the front one back to about half way along front door , and I'm pleased to say everything is tickety boo ![]() thank goodness for that ![]() |
