![]() | Home > Puma (Tdci) > Noise - metal to metal...... |
| lornick Member Since: 02 Sep 2009 Location: Aberdeenshire Posts: 32
Hi Guys
I have a noise coming from underneath the landrover which only happens when the wheels are rotating - (2009 110 utility) and can only be described as bare metal scraping against bare metal. At first I thought it may be one of the disk brake shields that had been bent and was coming into contact with the disk, but I've checked that out and everything is ok. However, when I rotate the rear wheel, the noise is clearly coming from the section where the rear propshaft is attached to the (diff?) - sorry, struggling to upload photo. I assume that this is a relatively straightforward fix, but would like to know what that fix should be? If I can upload a photo later I will, but in the meantime any help much appreciated. Rgds Nick R |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
prop uj seizing ?
of course check brake pads
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Start with the easy things first and in this instance a stone trapped between a brake disc and the tin weather-shield can make a holy din sounding like metal on metal. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| All times are GMT |
