![]() | Home > Maintenance & Modifications > what do you think about this |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
I like the grill....and would consider purchasing once the final product has been produced and there are more details apart from a few 'carrot dangling' CAD drawings and nothing else.
Entreq's quality of goods has never been questionable.....I personally would only buy from a UK supplier once they had stock if recent experiences from other forum members are anything to go by. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Isn't the issue with all of these types of replacement grill that they make the internals far too visible. Wouldn't be an issue but it's a right mess of brackets, wiring and wonky rivets.
| bjf Member Since: 03 Jun 2009 Location: Los Angeles Posts: 41
I'm in if you make it.
| Red Desert Member Since: 23 Aug 2010 Location: Lake Constance Posts: 53
I think you are right. There must be found another solution. Also the frame for the wires needs to be upgraded to one single solid piece and not a piece of thin sheet metal. |
