![]() | Home > Puma (Tdci) > Anderson connector fitting |
Simplest solution is take the supply off your 100 amp megafuse then stick a 30/40/60 amp in-line to your Anderson positive dependant on what you intend using it for. If those ratings aren't enough just rely on 'diversity' and the mega fuse. Do you know what the craking amperage is when jumpstarting?
http://www.halfords.com/technology/car-aud...6755&_ http://www.halfords.com/technology/car-aud...der-sn2-30 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 17th Apr 2015 4:54pm. Edited 3 times in total |
cut the terminal off and fit a different type
something like this eBay item number: eBay Item No. 381219697837 just need to get a heavy duty ring tag crimped on to cable you could fuse it , but would need to be 400-500a mega fuse something like this eBay item number: eBay Item No. 111105946492 |
think he will need something bit heavier than that for jump starting a horse box lorry tobz102 what size/amp rating Anderson connector have you fitted? Last edited by munch90 on 17th Apr 2015 4:56pm. Edited 1 time in total |
Realised that hence the edit.....
![]() Treat every day as if it is your last....one day you will be right!! |
k9f that link is for 30amp fuse ?
personally I would a lot heavier like min 300amp for jump starting ah ok sorry k9f , just read your edit about megafuse ![]() |
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 ![]() ![]() ![]() |
The horse box is only on a 3.5ton van chassis it's not a lorry as such.
I've fitted 175A durite connector.. |
the 175a seem to be the most common used for jump leads
