Home > Maintenance & Modifications > Suspension Advice Please
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
The suspension in my wife's 90 is rock hard. I swear to god it's that solid if you drove over coins on the road you'd be able to count how much change there was. It was not too long before we bought it that it had new yellow polly bushes all round and yellow heavy duty britpart springs and anti roll bars fitted if that's any help.
My question is....what needs to be done to make it a more smooth, comfortable drive? I realise I have to change things but what exactly needs doing? Do I change the springs, shocks, polly bushes, what? I have trouble with my spine and it's seriously putting a dampner on it when the wife wants me to go out in the 90 with her but I keep arguing for the comfort of my Discovery. I know i'll not get it luxurious like a Bentley but there must be something that can be done to make it more comfortable.
As always any advice is very much appreciated. Thank you Thumbs Up
Post #416202 14th Apr 2015 6:22pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Is it standard height Crispy? Did you keep the original parts? If so I'd swap the springs for the original L/R ones, it'll be the HD springs that will be causing most of the harshness. I swapped my suspension for Koni shocks, swapped all the bushes for Super Pro, stiffer anti roll bar on the back, new steering damper but kept the original springs as they're not too bad as standard, that's if they're not old or worn out, mine were in good shape.
That's the easy option, you'd be able to get the springs swapped over easy enough.
I'm not a suspension expert by any stretch of the imagination, but that would be the way I'd go.
Post #416211 14th Apr 2015 6:59pm
chrispy
No mate. With the HD springs it sits a natural 2 - 4 inches high which we like. There's no lift kit, just the springs. I didn't keep any of the original parts sadly.
Post #416212 14th Apr 2015 7:01pm
Anderzander
It's probably all of those Britpart components .... In particular the springs.
It's hard to beat standard items - and cheap springs are notorious for being of an inconsistent rate and often - rock hard.
There are different variations of standard springs - some progressive some heavier duty. Their rate is identified by a colour code.
New genuine springs are often not as expensive as you might imagine.
Additionally - lots of people take them off to put lowered or raised ones in - so there must be a fair number of good condition / new take off ones out there.
So - unequivocally my advise is go back to standard springs, and you could start by popping a wanted ad in here Smile
Post #416213 14th Apr 2015 7:35pm
chrispy
I don't mind paying Anderzander, I have no problem with that it's just the wife likes the 'natural' lift these springs have given it now so i'd need some that would give it the same ride height.
Post #416214 14th Apr 2015 7:38pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I have Britpart +2 HD springs on my 90. They have done over 15k miles, a lot of that over harsh ground. No problems with them.
They are paired with Koni Heavy Track shocks, and the ride is pretty good. Not soft but not too harsh either. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #416216 14th Apr 2015 7:46pm
chrispy
Hi Pam thanks for replying. I'm looking for more of a softer ride. The wife absolutely loves the way the 90 sits, it's big and it's perfect, it's just too hard a ride on my spine. I feel every single bump in the road and it's like an electric shock through my body.
Post #416217 14th Apr 2015 7:50pm
Anderzander
Chrispy - that leaves two options in my opinion... I recognise that Pam's experience has been good, but that's a minority in my experience.
So - For me it's new aftermarket good quality springs or genuine springs that would give it a lift.
There is a table online with the rates and lengths of all the genuine springs..... Just can't find it at the moment.
To state the obvious - lift from a spring can be obtained in one of two ways. A higher rate - so it compresses less (static sag they call it) under the vehicle weight - or longer springs.
For a softer ride than HD springs - but with the same lift you want longer standard rate springs.
Have you got the chance to drive a standard truck so you can get an idea of what suppleness of ride you want ?
Post #416218 14th Apr 2015 8:01pm
Anderzander
Another option is standard springs with spacers by the way - these being a very good one : http://pages.ebay.com/link/?nav=item.view&...1183310701
Post #416221 14th Apr 2015 8:02pm
chrispy
Thanks very much my friend, I'll certainly look into it. As long as I can keep the ride height and get some comfort I'll be happy Thumbs Up Yes I have got access to a non modded one to get a feeling of how I want it.
Post #416223 14th Apr 2015 8:12pm
Anderzander
I've no connection - but that seller on eBay is a good guy - Gwyn Lewis.
You wouldn't get bad advice from ringing him and saying you've seen his lifting spacers and why your interested ...
A very genuine and knowledgable bloke who understands Defender suspension very well.
Post #416226 14th Apr 2015 8:16pm
Lambley
Ander's is right, but you need to find out what's fitted to yours at the moment, I bet they're Britpart Heavy Duty +2" - DA4202 front, DA4203 rear, the rears are rated to 300-340lbs, which is harsh, you'd be better of with medium or light load springs os say 220lbs - then get the fronts to match - like these -
http://www.ebay.co.uk/itm/DEFENDER-90-2-RE...58a6acc97f
Post #416228 14th Apr 2015 8:17pm
chrispy
Excellent. I'll show all of this to my mechanic and he can work out what I need. I'm bloody hopeless myself. Thanks to all for your excellent advice and help. This is a superb community Thumbs Up Bow down
Post #416233 14th Apr 2015 8:21pm
Pam W
If people read what I said above, I DO NOT find the britpart HD springs a harsh ride at all. Firm, but not harsh. You have to consider shocks as playing a huge part in the ride, not just the springs.
The Britpart springs are progressive, and matched with a good quality adjustable long travel shock like the koni Heavy track they are a comfortable ride. I have back problems too, but with this set up it doesn't hurt or cause me issues at all!
We did loads of calculations to get the best heights and compressions for our purposes (general travel and also fully loaded expedition travel). We did the sums and bought the springs to match the purpose. Was not done on price. And by the way, not all Britpart stuff is crap. We also did a lot of searching for reviews and the Britpart HD springs actually have a good reputation! Our blog - http://landytravels.com/
Post #416318 15th Apr 2015 8:26am
chrispy
I didn't interpret your post like that at all Pam and I thank you for your input. As a fellow back sufferer your words have been taken on board and will be presented to my mechanic who carries out the work. How high does your 90 sit if I may ask? This is my wifes in the picture below and if it dropped one little bit she'd have me for breakfast. I really don't want to change the ride height at all, just soften the experience when driving. It's been practically rebuilt from the ground up by the previous owner, I just wish he'd gone for a smoother ride.
Post #416321 15th Apr 2015 8:57am
