Home > Technical > any one for a stupid question?
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
How does one jump a car with their defender? is it a seat removal thing or is there a battery post somewhere I am missing?
Thanks 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #41533 29th Sep 2010 11:35am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Seat removal Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41535 29th Sep 2010 11:53am
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Re: any one for a stupid question?
A big ramp is needed usually, depends on the size of the car though.
But no, seat removal and some interesting parking skills are required depending on what it is your jump starting.
Post #41536 29th Sep 2010 11:56am
I can jump higher than my defender ....
.... my defender can't jump Laughing
Post #41540 29th Sep 2010 12:20pm
johnnyturbo2002
so your "White" Defender can't jump...? 2008 Defender 110 60 year Edition (sold unfortunately)
Post #41543 29th Sep 2010 1:12pm
Grockle
becareful look what happened to poor old Eddie Kydd 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #41544 29th Sep 2010 1:27pm
Fit an Anderson socket to the front bumper
Post #41553 29th Sep 2010 3:02pm
K9F
Found the remains of an Anderson Shelter in my garden when digging my gazebo foundations! Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41557 29th Sep 2010 3:39pm
johnnyturbo2002
OK, I'll bite, ( the American is showing now..not the biting, although a good nibble is fun every once in a while) but I digress...what is an Anderson socket...and why would one be finding it while digging for a foundation...? 2008 Defender 110 60 year Edition (sold unfortunately)
Post #41565 29th Sep 2010 5:40pm
johnnyturbo2002
never mind, googled it.
still thinking about the nibblin' though....oh honey Whistle Mr. Green 2008 Defender 110 60 year Edition (sold unfortunately)
Post #41566 29th Sep 2010 5:43pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I've done this and use it a lot a work. So much easier that having to keep removing the seat. One of the best mods I have done.
Boy
Post #41609 30th Sep 2010 7:47am
Grockle
but did it still have the socket in it ? 2.4 90 XS
Post #41613 30th Sep 2010 8:55am
leeds
Anderson shelter = World War 2 (1939-45) bomb shelter used in the UK normally made from corrugated sheet metal and half/fully buried in gardens etc.
Anderson sockets are genderless, inductrial DC connectors
Genderless means no plug or socket. You need two Anderson connectors to make an electrical connector.
BEWARE of generic/look alike Anderson connectors! They can be of much lower quality in the plastic mouldings and the electrical contacts! I would not assume that non Anderson/generic connectors will connect to genuine Anderson connectors
Four different sizes, rated at continuous 50/120/175/350 amps but capable of carrying higher currents for shorter periods of time
The different colours relate to advised DC voltage from 12V to 144v. They are mechanically keyed so that it is not possible to fit a yellow one to a blue one etc.
12volt is normally yellow
24 volt is red
36 volt is grey
Typically in the UK the grey one is used on Landrovers. Warn winches use red ones!
The contacts are normally crimped onto the cable. Either an electrical indent cable or a hexagon hydraulic crimp
They can be soldered on as well. Use damp tissue to stop insulation melting.
hey can be mounted on the front of a Defender battery box
or like this
If fitted to a bumper use an isolation switch and a red rubber cover.
Jump leads/compressors/'cordless' drills/work lights etc can be fitted with an Anderson connector
HTH, apologies for long post
Brendan
PS No such thing as a stupid question. However there can be stupid answers Razz :lol:
Post #41614 30th Sep 2010 9:01am
Grockle
there certainly heavy duty leeds Whistle 2.4 90 XS
Post #41617 30th Sep 2010 9:06am
leeds
BEWARE of some cheap leads!
I have seen some offered for sale at about 40 rated at 400 amps. Then you look at the spec. 175 amp 'Anderson' type connector. 25mm2 cable and baby clips.
The ones we have use genuine 175 amp Anderson connectors, 35mm2 hiflex cable rated at continuous 240 amps and 300 amp clips.
Now how can 25mm2 cable safely carry 400 amps!. Then there are the 800 amp jumpleads wich use 16 or 25mm2 cable! Stand back and warm your hands!
Brendan
Post #41619 30th Sep 2010 9:15am
