![]() | Home > Maintenance & Modifications > Multiple and individual lights |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
Yes you can mate. its all about switches and relays.
How many lights are you talking about. |
chrispy Member Since: 14 Mar 2015 Location: Gwent Posts: 347 ![]() ![]() ![]() |
LED light bar on the roof, front spots on the bumper, side lights either side and work lights at the back.
I'm no expert in vehicle electrics but this would be my thinking.
Install and additional fuse box in the battery compartment. Install a bank of switches into your cubby box and switch them all separately. You could then install a relay to switch all front lights on together, I can't see the point of having the rear ones on with the front. ![]() |
Ready for the zombie apocalypse lol. Thanks very much my friend
Your welcome
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 298 ![]() ![]() ![]() |
If you want to avoid extra relays etc etc then in line diodes are your friend. They usually come as a 10a black cased unit, a bit like a stubby pen tube with a 6.3mm male blade crimp on one end and a female on tother.
Use them to isolate the LED feeds individually, then just feed them all from a common relay elsewhere, just be careful of the 10a limit (or double them up etc). Do bear in mind they are about 3 inches long so not good for very tight spaces, but fine for trunking. On my freelander I have my headlight full beam linking into two seperate banks of LED Spots, but these can be also turned on manually. As a third twist, I can also link and unlink the LEDs into the main beam at will. Hope this helps. Duncan @ UTV Products (Led Lighting Suppliers) North Cumbria Search and Rescue - Team Leader |
Very helpful many many thanks
I'm at the planning stage Duncan and just found your website. When the time comes i'll be in touch and you can help me out with everything I need if you don't mind. |
Hi mate. Absolutely not a problem. I would have linked to it but don't want to poke Martin with a pointy stick just yet haha. Drop me a PM any time. North Cumbria Search and Rescue - Team Leader
Thank you my friend. A little way off yet i'm just getting everything down on paper as to how we want it to be. I love your LED bar's especially those colour changing ones, i've never seen those before.
