Home > Maintenance & Modifications > Battery warning light
Cheshire Dave
When idling after a few mile journey the battery warning light pulses on and off, goes out if you increase the revs though but when pulsing there seems to be a different engine sound. Any ideas, is this a potential problem looming. Or am I being paranoid ?
Dave
110 300tdi
Post #415273 10th Apr 2015 10:45pm
munch90
You say engine sounds different, is it ticking over slower ?
Post #415275 10th Apr 2015 10:48pm
K9F
Under fault conditions measure the output of the alternator with a multimeter, it should be ballpark 14 volts. Once running a diesel obviously doesn't need a battery to keep running, if you have the technical accumen you could also carefully disconnect the battery positive and measure the voltage on the vehicle terminals to see if your battery may be shot and is dragging the alternator output down, or if you have a spare battery (or perhaps 'borrow' one from another vehicle) chuck that in. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #415282 10th Apr 2015 11:35pm
Cheshire Dave
Thanks guys I'll get it checked out, battery was ok late last year and hasn't been checked since.
Post #415297 11th Apr 2015 7:24am
mikeh501
I found to my cost that isn't exactly true. Even on my old TDI unit the diesel stop solenoid is electrically operated in that the voltage keeps it open. Once the battery is fully goosed then it drops back and cuts off fuel from the engine. I'd guess the later engines are even more reliant. Took 3 days to happen like Mr. Green I wondered why my wipers were slower than normal lol
Post #415299 11th Apr 2015 7:34am
munch90
could really be a few different things
tick over speed dropping causing alternator to spin to lower rpm that can make light flicker also different engine noise
belt slipping
diode in alternator , will still charge but at lower rate
as said check voltage on tick over and revving a bit and with headlights on to load alternator a bit
dodgy battery wont normally put alternator light on , unless its really knackered then defender shouldn't start at all on the battery
Post #415313 11th Apr 2015 8:43am
