Home > Maintenance & Modifications > Battery question
Busboy
Battery question
Hi all, I have a 110 SW on an 11 plate with the original battery fitted.Now after 3 days non use there was not enough crank left in it to start the engine i am running the standard alarm and tracker.
I noticed (i think ) that it is only a 70ah battery. Do i now need a larger one?
The ctek is now doing the battery reconditioning program so we wil see! Razz Steve
Post #415219 10th Apr 2015 5:40pm
munch90
3 days seems very little time for a battery to last , really you need to test current draw when stationery and turned off
have you got a multi meter to test it with ?
and then get battery drop tested to test that
the ctek battery recon thing is only any good if you have a good battery thats been really discharged and left in discharged condition for a while ,if the battery is knackered its knackered !
Post #415223 10th Apr 2015 6:12pm
Busboy
Thanks Munch90 I will try to test with my multimeter Thumbs Up Steve
Post #415227 10th Apr 2015 6:24pm
jaydt
2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mine to is a 110sw on an 11 plate and after two days the ctek indicator flashes amber after two days and red after three days. Only used a few times a month so think battery is on way out. Also Standard alarm and tracker. Strange
Post #415244 10th Apr 2015 7:49pm
Busboy
Yeh, the funny thing is that on my motorbike the Amp hr on the crank is 140 so me thinks that 70 Amp hr is rather poo Yawn although I'm no engineer or leccie no doubt i will be corrected. .....
Sorry for my failings in advance Rolling with laughter Steve
Post #415248 10th Apr 2015 8:28pm
munch90
The motorbike battery 140a would be cranking amps , defender battery would be roughly 850a cranking amps , 70ah is the amount it would slowly give out
Post #415265 10th Apr 2015 9:57pm
Busboy
Thumbs Up Thumbs Up thanks munch90
I knew i would learn something, that's what I like about this forum .... Steve
Post #415295 11th Apr 2015 7:14am
LR90XS2011
mine is an 11 reg and used infrequently, I have noticed it takes about 3 weeks for the battery to discharge enough for the cranking to be so slow to threaten a none start so I now put it on charge after about 2 weeks of no use. I suspect the problem is use related, the clock, alarm and any other active security devices will be draining the battery all the time. If you have a tracker most of them will tell you when you need to charge it up via the low voltage/disconnect warning. Clearly if you have an intelligent charger I would just leave that on all the time. If your journeys are short even if used every third day or so you may not be getting a full charge into the battery even for it to last 3 days. you may find a full charge every few weeks will suffice and the battery will last a good few more years and last more than 3 days DEFENDER 90 TDCI XS,
Post #415300 11th Apr 2015 7:39am
munch90
personally im not a lover of leaving any kind of charger connected and on 24/7
personally use a time switch to switch charger on and off , if everything as it should be (battery , no excessive drain etc ) you should only need to charge 15-30mins ( max 1 hour ) a day even on a trickle charger
Post #415315 11th Apr 2015 8:55am
