Home > Puma (Tdci) > Too low Coolant temps? (Warm climate overheat..)
Page 6 of 9 <123456789>
dgardel
Italy
Please buy the thermostat only original
Exists a lot of fake pieces Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #413792 4th Apr 2015 6:30pm
pannawonica
Australia
Thanks dgardel I wil the fan out! Thumbs Up The thermostat was from a reliable Aussie supplier. Very Happy
Post #413862 5th Apr 2015 1:13am
ericvv
PEL500110 (grey soft spring 82°C version) ordered from my Land Rover dealer yesterday. They told me that on their screen it shows up as an original part for the FL II which seems to match the discussion here.
It will be installed next week friday when the truck goes in for its semi-annual oil/filter.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #415020 9th Apr 2015 2:59pm
pannawonica
Australia
After what Dg said I double checked! That's the one I have Ericvv. I have now done several continuous 1500Km runs,( other than fuel stops.) with noworries! Thumbs Up
Post #415186 10th Apr 2015 12:47pm
Eduardo
I will install mine during the weekend
Let's see what happens Eduardo
Post #415261 10th Apr 2015 9:46pm
I have the grey soft spring genuine Land Rover one .. Will try and install at the weekend
Post #415280 10th Apr 2015 11:32pm
pannawonica
Australia
I look forward too your impressions of this mod! Thumbs Up
Post #415290 11th Apr 2015 2:22am
LR90XS2011
Munch 90 is the black one you recommend PEL500110 or PEM101020 Rover forums and internet sellers have confused me. DEFENDER 90 TDCI XS,
Post #415293 11th Apr 2015 6:23am
munch90
PEL500110 is gray one
PEM101020 is black one
but if you get them to check stock then go and get them to check colour to make sure , as there have been some mix ups with numbers
Post #415304 11th Apr 2015 8:19am
ericvv
Eric
Done, PEL50110 installed today Thumbs Up
And good thing is that dealer also entirely purged the coolant system and refilled with new anti-coolant mix. So all corrosion inhibitors and other additives are up to snuff again, well before the 10 year prescribed for this job by JLR.
Post #416885 17th Apr 2015 5:05pm
pannawonica
Australia
How are you going with the new thermostat people? Very Happy Thumbs Up
Post #416980 18th Apr 2015 5:15am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Eric, I am very interested to see what the new thermostat does to the running temeperature.
I was surprised to see that on one of the uncharacteristic warm April days last week(still only 22°), on a faster run, the water temperature crept up to 94° on the Ultragauge.
Add to this another ten to fifteen degrees outside temp and a heavy trailer.... 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #417041 18th Apr 2015 11:58am
pannawonica
Australia
All I know is 50degC and a heavy trailer and boiling do we go! Thumbs Up
Post #417159 19th Apr 2015 2:15am
ericvv
Wild Card, do you have the standard thermostat? If so, what you say is pretty normal I think, as the standard thermostat only seems fully open at 96°C.
Now, I may never find out what this PEL500110 gives as a change in running temps. I have no ultragauge, not really interested in it. So only thing I can go by is my standard water temp which does not move above the middle unless you have a boil....
What I would like to add is a simple VDO water temp gauge, one which shows the real water temp, but it seems not so easy to find a spot to install the sensor for that. It has been discussed in an older thread, but without resolution....
http://www.defender2.net/forum/topic28536....water+temp
Post #417162 19th Apr 2015 3:46am
ericvv
50°C and a heavy trailer? Shocked Not really surprised, are you? That is like trying to cool the radiator by blowing hot air from a hairdryer into it. Laughing You never actually own a Defender. You merely look after it for the next generation.
Post #417163 19th Apr 2015 3:53am
