Home > Maintenance & Modifications > Urban Truck DRL
Page 2 of 2 <12
Davie L
Scotland 2008 Defender 90 Puma 2.4 HT Orkney Grey
Sorry JayBoy
I picked you up wrong, Your right White is ignition live.
Davie
Post #414911 8th Apr 2015 10:41pm
JAY BOY
Wales
Thumbs Up
Post #414913 8th Apr 2015 10:43pm
Likeomg
I'm making my own when the lamps turn up... wonder how mine will be to wire
Post #414926 9th Apr 2015 12:21am
I took the ig live from the Heater Fan Thumbs Up
Post #414934 9th Apr 2015 6:22am
If you are considering a few modifications, consider fitting a vsr in the battery box, then you will have a hefty ignition on live power source for example a sub woofer too Mr. Green
Post #414939 9th Apr 2015 7:23am
CLCraig
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
bpman is that how you've done yours?
Post #414943 9th Apr 2015 8:27am
I don't have DRLs anymore - but I fitted the VSR for other accessories like a sub, cruise control etc
It's amazing how many items you want to run on ignition live and the VSR switches a few seconds after the engine is started
Post #414944 9th Apr 2015 8:30am
munch90
only small possible problems if using a vsr as ign live are
1 if you want to fit a battery charger like a ctek then as voltage rises when charging the systems connected to vsr become live
2 only live when engine running ( good for not flattening battery , not so good if you just want anything on with ign on not running
good for some things , not so good for others
other way is run two wires to battery box 1 x ign live taken from cig lighter , 1 x from 1st click aux live like radio live , you only need small wires say 5 amp wire so the two can run togather in small protective sleeving , then use these just as switching feed for relays mounted in battery box then in future anything you fit can be run from the relays without needing to pick up feeds anywhere again , this way you don't need to keep altering vehilcle wiring
this way is a bit like future proofing your wiring for added toys later on , sub , fridge , aux sockets , extra lights etc
take perm feeds from battery for relays via 30-40 amp fuse to muilti outlet fuse box for lighter feeds off that
there only small wires so don't run anything direct from them , always though relay , one 30-40 amp relay will run most toys just need to add up total load when adding anything
all depends on how many toys you might add in the future !!
Post #414946 9th Apr 2015 8:46am
CLCraig
Thank you munch makes a lot of sense. I'm fine with mechanical work but wiring baffles me.
Post #414959 9th Apr 2015 10:07am
Wiring is simple it has a pulse or it doesn't Mr. Green
Post #414970 9th Apr 2015 11:15am
CLCraig
Got it all fitted and am very pleased with the results certainly got some looks.
Post #415792 12th Apr 2015 8:16pm
JAY BOY
Wales
Nice job Thumbs Up
Post #415797 12th Apr 2015 8:31pm
Page 2 of 2 <12
