![]() | Home > For Sale & Wanted > [Wanted] 12x wheel arch fixings for Puma |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
I have ten here brand new.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Just push the pin all the way through 'till it falls out (collect the pins, of course), then refit from the front when put them back. They take seconds to remove.
Refitting is easier if you use a little lube on the pin. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Blackwolf, I got one out that was easier to acess but some of the others wouldn't move which was a right pain so I left it for today. Suppose WD 40 or similar may help.
Might be a good idea to get spares anyway if the break. Lee - How much would you want for those mate? 10 would do as I expect I could save two at least. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
Poke pins through, and if lost use a small black self tapper in it.
![]() ![]() When I have brought new, I've got them from Si at MPS, Andy |
If you lose the pin, another alternative is to replace it with a short length of fence wire or wire cut from a wire coat-hanger.
piecost76 Member Since: 29 Sep 2010 Location: Nr Sevenoaks, Kent Posts: 177 ![]() ![]() ![]() |
We supply these to many bodyshops so give me a photo & I will see what I can do
![]() 2015 110 XS UW sadly stolen 21/11/2017 |
I've got some now from Duckworth parts. Thank-you for your kind offers though everyone.
