![]() | Home > In Car Electronics > What slim Subwoofer and where in a 90 HT |
The genuine subwoofer cubby is actually shorter than a standard one.
This doesn't matter in a 90 but will foul the 2nd row seats when folded in a 110 |
Buy one of our shorter cubbys
![]() I've also seen them mounted under the second row seats on the seat itself ... |
I have a focal i20 and I've fitted it under middle row seats .. Alternative place under front seat using entreq seat adaptor box
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 749 ![]() |
I want to fit the Alpine sub as well, though I will need to think of somewhere else to mount it as there defo won't be enough room after fitting your twin din cubby into my 110HT.... ![]() |
That's for sure
![]() ![]() Don't forget that subs don't need to be 'symetrical' ie you can put it in a corner or off to one side |
Cool. Maybe onto the bulkhead behind passenger seat would do the trick.
That would be perfect !
It would be worth mounting it on a piece of thick MDF first (perhaps covered in carpet for aesthetics) to stop the bulkhead steel vibrating |
Yeah my whole bulkhead will be covered in vibration damping material as I will have an ARB compressor mounted on it as well.
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
Martin, as i ordered a new leather cubby top from you last week ![]() |
