![]() | Home > Maintenance & Modifications > Electric Window Upgrade |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
When you take the window winders off I used two of these grommets to cover the holes. If you carefully cut the backs off with a Stanley blade so you are left with a flat rubber circle and then super glue them over the hole it finishes off the trim panel really neatly. Go for the 50mm size.
http://www.ebay.co.uk/itm/6-9-12-16-20-25-...258f46f03b For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Buccaneer Member Since: 11 May 2014 Location: London/Kabul Posts: 148 ![]() ![]() ![]() |
Strangely this is only for a 110 not a 90 - i checked with the vendor and they said 110 only? Are the doors different from a 110 to a 90? Am i being really dumb here? The Rules:- 1 Buccaneer comes back alive. 2 Chicks dig scars. GB260 |
90 and 110 front doors are identical
That's what i thought - so in theory this should work on my 50th? The Rules:-
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17867 ![]() ![]() ![]() |
The rear door winders on a 110 are different to the front door winders I believe, so it is possible that they may be kits for the rear. I can't see any mention of this in the listing though.
Front doors are identical as noted above. |
Looking at that kit I am not too sure it is for front doors, I would message the seller to make sure.
Saying that I would opt for genuine defender electric window regulators, a pair will cost you about £160.00, wiring is not that expensive and you may find that you already have the wiring in your loom anyway. Genuine switches are about £15.00 each. With genuine parts you know they will fit are of quality manufacture and are guaranteed to work. Ok you may pay a little extra but in the long run it will be worth it to have a genuine parts vehicle. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
They have confirmed they are for the front doors. The Rules:-
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1388 ![]() ![]() ![]() |
......... that would be the very article ![]() |
