Home > Off Topic > Trailer auto reverse brakes
excossack
Does the auto reverse brakes on trailers work off the hitch, or just within the drum or a combo of both ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #413942 5th Apr 2015 1:09pm
munch90
the hitch pushes in the same as when you brake but in the drum , as the shoes grip to brake but as drum turns backwards as you reverse , some go down a ramp inside , others on a kind of cam action
there are a few different kinds , but as far as I know there all in the drums
Post #413982 5th Apr 2015 3:42pm
excossack
Thanks - I thought might be the case, 1999 Defender TD5 110
Regards
John M0VAZ
Post #413998 5th Apr 2015 5:20pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Just a word of caution.
If you reverse a trailer/caravan with auto reverse brakes make sure you pull the draw bar forward with the tow vehicle , this will put the brake shoes back to the correct position and allow the hand brake to be applied.
I have seen first hand what happens to caravans/trailer that have been reversed into a spot, caravan/trailer hand brake applied, vehicle unhitched and driven away only for caravan/trailer to move off on its own. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #414005 5th Apr 2015 5:54pm
excossack
Thanks for the tip. 1999 Defender TD5 110
Regards
John M0VAZ
Post #414008 5th Apr 2015 6:23pm
