Home > Technical > How much travel does a stock 110 have?
Mech
I've google the crap out of this and can't seem to find an answer. Does anyone know how much travel a bog standard 110 CSW has?
In case theres some variance, heres specifically what I'm running...
200 tdi
boge unit removed
Salisbury Rear
Bearmach OEM replacement springs
Bilstein B-6's
16x7 Modular Wheels with a BFGoodrich 235/85-16's fitted
Post #413609 3rd Apr 2015 8:53pm
Mountain_man
Wales
I once travelled 3000 miles in two weeks in a stock 110. Very Happy
Post #413615 3rd Apr 2015 9:13pm
Eduardo
... Eduardo
Post #413616 3rd Apr 2015 9:35pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You don't have a stock 110 so not sure what you're asking ?
The limiting factors on the rear of a 110 are normally the length of the shock absorbers, the weight of the vehicle (effects the "starting" point), the A frame ball joint and the radius arms and bushes.
In "stock" trim they have a pretty decent amount of travel, not sure you'll find a measurement as such, if that's what you're looking for, because there are too many variables around individual vehicles and the circumstances. The theoretical limit is around 20mm past the bump stop upwards and the length of the shock absorbers downwards but it's rare it's as simple as that. http://www.yorkshireoffroadclub.net/
Post #413623 3rd Apr 2015 9:53pm
Mech
Um thanks
Post #413642 3rd Apr 2015 11:21pm
Cupboard
you could always drive up a ramp?
Post #413814 4th Apr 2015 8:29pm
Mech
Appreciate the effort, but suspension travel is an automotive industry standardized engineering measurement. It doesn't "depend". It's like "turning radius" or "minimum ground clearance". There are formal and established ways of doing these measurements such that objective comparisons can be made between models. If I recall correctly, it must be measured at the center of the hub and correspond only to the vertical delta between full droop and bump stop. I also believe this measurement must be conducted with the vehicle in a static position such that the three non-measured wheels reside in a plane parallel to the ground. I'm not a practicing suspension engineer though, so I'm not 100% certain.
No worries. I'll contact LR. Thanks for trying to help.
Post #413817 4th Apr 2015 8:45pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Surely the above comments do hold true though.
Your shocks aren't standard so you're travel figure will be different (no matter how small) to that of a bone stock Defender.
Are you running a standard A-Frame ball joint or one with slightly more flex?
Perhaps both myself and the above posters have misinterpreted your question, but your travel will be different to whatever LR tell you. No matter how small?
Post #413832 4th Apr 2015 9:37pm
taazzukcb
Having re-read your last bit, are you after the calculation? Not the figure?
That may make the question make a bit more sense?
Post #413833 4th Apr 2015 9:39pm
Mech
I added the comments about my own vehicle as secondary information in the event somebody knew the actual answer for the first and only question posed. The question posed was relative to a stock vehicle. In the event that someone answered the first question, then I was open to conjecture about how mine might perform relative to the stock vehicle. I agree that I didn't provide sufficient context for giving my own specifications. The first post was rushed and I didn't compose it adequately. Apologies for the lack of clarity.
Post #413844 4th Apr 2015 10:36pm
taazzukcb
Makes sense Smile Thumbs Up.
Does this help:
Quote:
Long-travel suspension
Excellent axle articulation, thanks to coil sprung suspension, also plays its part in Defender“s
legendary ability (655mm and 590mm for Defender 110 and Defender 90 respectively) by helping
the wheels to maintain contact with the ground and follow the contours of rough surfaces.
Post #413853 4th Apr 2015 10:55pm
Mech
That is a very impressive number. One of these days I'll measure mine.
Post #414004 5th Apr 2015 5:47pm
