Home > Puma (Tdci) > A new rattle... **SOLVED**
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
I've got a new rattle! Only noticed it today on the motorway, seemed to do it above 50MPHish. When lifting off (i.e. taking your foot off the accelerator) there's a rattle from the back, sort of sounds like a thin sheet of metal flapping into another bit of metal... Hope that makes sense? Had a quick goosie underneath but couldn't see anything loose.
There's nothing in the back that could be making the noise, and besides it sounds like its coming from underneath somewhere.
Any ideas, or is another trip to the dealers due?
Post #33634 3rd Jun 2010 5:28pm
MK
Re: A new rattle...
Try the rear mud shield on the propshaft. Puma 110" SW
Post #33682 4th Jun 2010 1:18am
warren
Am I just being dim or am I missing something, can't find anything shield related anywhere near the prop... Confused Confused
Post #33729 4th Jun 2010 6:12pm
herbie
England 2009 Defender 90 Puma 2.4 HT Cairns Blue
Hi Warren
I have the same problem (hence joining the forum) The rattle from the rear !! Big Cry
Did you find out what the problem is please?
Many thanks Herbie
Post #41374 27th Sep 2010 10:13am
warren
Hi, I should have put a reply on the forum when I got it sussed... whoops.
But it turned out to be the roll pin in the rear diff that had worked itself loose.
Post #41380 27th Sep 2010 10:52am
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Would be good to add *SOLVED* to the thread title. Saves time for many.
Post #41392 27th Sep 2010 1:36pm
warren
Thumbs Up
Post #41395 27th Sep 2010 2:21pm
nickhodgson
Hi,
What is the roll pin in the rear diff and how did you find this out?
Post #41443 28th Sep 2010 8:51am
warren
Well, I could be wrong so feel free to correct me, but I beleive it locates the pinion gear, and because the pin is harder than the casing it fits into it wears the hole & makes it bigger... Although I could be wrong.
I went for a drive with a mechanic from the dealers who knew exactly what it was right away.
I have a picture of an older diff that blew on my old 90 somewhere, that shows the roll pin.. I'll see if I can dig it out when I get home.
Post #41453 28th Sep 2010 10:42am
