Home > Maintenance & Modifications > Stainless steel EGR blanking kits
Page 13 of 16 <123 ... 1213 141516>
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Laughing Successfully connected the BAS remap tool and cleared down the errors just as explained - very easy indeed, will let you know if the light comes on again, if it does then I will move on up to the next size, 14mm I believe.
Post #41289 25th Sep 2010 7:18pm
DAZ110
.....and I've done the same!....but will be 12mm plate for me.
Post #41298 25th Sep 2010 9:17pm
BIGFOG
Big Cry 50 miles later and the light is lit once more, looks like my Puma needs a bigger hole! Time to hug my engine again!!
Post #41337 26th Sep 2010 7:00pm
K9F
BigFog,
I also had the same sometime ago turned out it was my EGR valve itself that was knackered. May be worth just running without a blank for 50 miles or so just to prove servicability of your EGR perhaps??? They are notoriously unreliable and temperamental! Or just go bigger and try it as you suggest. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41340 26th Sep 2010 7:23pm
BIGFOG
Thanks K9F, you may well have a point there, does anyone know why the Puma cannot take the normal bypass/delete kit offered to all other variants? I just hate the idea of pumping any exhaust gasses into my engine, isn't that why they fit exhaust pipes to the back of cars??
Post #41345 26th Sep 2010 8:04pm
PDH
Dropped Down to the 10mil plate 12 days ago and drove to Andorra and back, seems the the 10mil plate had a dislike for the outskirts of Paris!!!!
Out ward journey just near Paris the engine light came on .... Censored ! Cleared the codes with the trusty BAS box and off I went again no problems for another 6 days.......spookily.....on the way back....similar location outside Paris the light came on again!!!!!!!
Same process....cleared the codes and continued on without any further issues.
Apparently the truck loved Andorra and would like to live there but clearly stated that she did not want to move to Paris
So were home and happy in wet Northumberland:-) Puma 2.2 90 Stationwagon
Post #41376 27th Sep 2010 10:42am
PDH
Post #41377 27th Sep 2010 10:43am
K9F
You're welcome! If the EGR Valve on the Puma is totally blanked you will have a permanent MIL light due to mass air flow! People have done it but it is personal choice.
If you drive with a permanent MIL light this could potentially mask a more serious problem should it arise! There are several people currently working on devising an EGR deletion kit for the Puma that does not illuminate the MIL light when fitted!! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41403 27th Sep 2010 5:48pm
BIGFOG
Thanks K9F, I certainly don't want to drive around with the MIL light on permanently because of the risk of not being aware of other potential problems as you rightly say, but what has changed between the TD5 where you could delete the balve entirely and the Puma where we can only restrict airflow through the same valve which as you point out, may still fail?
Back up to a 14mm plate now and a word of advice to anyone changing plates - do not remove all three bolts that hold the EGR pipe in place at the back of the cylinder block, because if you do, the little black bracket falls down into an almost impossible position. I had to strip quite a few things out of the way before I could reach it and still drew blood to get it back - either undo the two lower bolts to release the pipe from the bracket, or the upper bolt alone to release the bracket from the block. Big Cry
Post #41426 27th Sep 2010 9:57pm
K9F
BIGFOG wrote:
but what has changed between the TD5 where you could delete the balve entirely and the Puma where we can only restrict airflow through the same valve which as you point out, may still fail?:
In layman's terms the difference is that there is a Mass Air Flow Sensor in the line that when you blank off the EGR Valve the sensor does what it says on the tin and senses that the MAF is out of tolerances and throws up the MIL light. Electrically disconnecting or attempting to short circuit the sensor does the same thing I believe!
Someone 'in the know' may be able to elaborate further if you need! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41438 28th Sep 2010 7:12am
Tim seymour
Australia
hi iam back today my light came on took it down to my garage and thay removed the codes it was the ERG so i took the 16mm out replaced it with the 18mm it had done about 800km on the 16mm will see how the 18mm gose and let you people know cheers for now tim Sad Cess the Taswegian
Post #41718 1st Oct 2010 11:15am
BIGFOG
Done about 2000 miles on the 14mm plate and all of a sudden the MIL light has come on, I'm beginning to think the mass airflow sensor needs a clean and all will be alright? Will give it a go at the weekend with any luck and report back. Thumbs Up
Post #43071 19th Oct 2010 9:02pm
Tim seymour
Australia
hi i am still on the 18 mm no problems but can some one tell me where this mass air flow censor is located cheers tim Smile Cess the Taswegian
Post #43176 21st Oct 2010 7:09am
Amos
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
What is this EGR thing all about, really lost with it....?!?!
Post #43609 26th Oct 2010 9:48pm
AndrewS
So it looks like the 19mm � is the one then Whistle 130's have feeling's as well you know Smile
Post #43612 26th Oct 2010 9:55pm
