Home > Maintenance & Modifications > swapping out mud flap brackets and front bumper Advice
steve E
Wales
Hi Gents and Ladies
I am looking at swapping out the original mud flap brackets and front bumper on my 110.
Nothing visually wrong with the ones on the car but as it's going to be kept past it's 3 year warranty term I would like to know
if anyone has found and used superior branded replacement parts that wont need changing every 3 years.
Many thanks
Steve
Post #413136 2nd Apr 2015 9:01am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I fitted Entreq Stainless Steel mud flap brackets to front and rear, these are powder coated black so look stock. Down side is they are horrendously expensive Big Cry but I was prepared to pay for something that is never going to corrode unlike the originals.
Post #413149 2nd Apr 2015 9:29am
munch90
ive not had a problem front bumper corrosion but first four ones seen to be better made
flap mounts , for cheapness buy replacement ones and rub down and repaint better before fitting and put some anti rust wax on the bolt threads before fitting and on the mating surface between bracket and chassis
Post #413150 2nd Apr 2015 9:39am
90mojo
Very timely advice Munch90, fitting a set of new LR front mudflaps to my 90XS HT this weekend. Thumbs Up
Post #413156 2nd Apr 2015 9:50am
munch90
nice thick layer of black wax on mating surface (you will get messy ) bolt up so waxoyl oozes out of joint , wipe off excess from along joint , seals the joint stopping water getting in
plenty of waxoyl on threads ( very commom for seizing up ) , because you will need to take off again at some time , there mud flats so will get stone chips in paint etc
Post #413160 2nd Apr 2015 10:03am
steve E
Wales
Thanks for the replies so far guys.
will check cost of originals verses nakatanenga ones.
Has anyone found a top notch Bumper replacement?
Post #413175 2nd Apr 2015 10:49am
Scoobeenut
Sorry Steve E it wasn't Nakatanenga it was Entreq that I fitted, bought them from 4x4 Overlander.
Post #413184 2nd Apr 2015 11:49am
Canberra Man
Steve E
Take a look at Devon 4x4, enter D44DEFNOWINCHSTD in to the search box.
5mm heavy duty bumper with some serious front recovery points.
Received mine last week, not fitted yet but I'm very impressed with the build quality.
Treat yourself to some stainless fixing bolts at the same time
Post #413209 2nd Apr 2015 1:31pm
Take a look at the Gwyn Lewis front mud flap kits on our website.
Galvanised brackets and they move the front flaps forwards to stop muck up the side of the doors.
Also included are panels to 'finish' the inner wheel arch, protecting the outrigger
Post #413213 2nd Apr 2015 1:51pm
gilarion
Got fed up with bumper rusting so fitted a stainless steel one. Front and back Mud flap brackets replaced with Galvanised ones and sprayed black.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #413224 2nd Apr 2015 2:38pm
steve E
Wales
Thanks guys
Will post pics once I've swapped out.
Post #413257 2nd Apr 2015 5:37pm
ericvv
Even with standard wheel and tire sizes I would make a case for the Entreq front mudflap extensions. Sit about 3 cm further out, so help (a bit) to keep the side of the truck cleaner when it rains. They are especially top SS quality, and I have proof that 1.5 years after I installed them, the powder coating remains as new.
Here is an installation link with before 'n after pictures...
http://www.defender2.net/forum/topic22400....t+mudflaps
For those with a 110, Entreq do not offer a replacement set for the rear mudflap holders, so I bought those from Offroad-Tec. Good quality by the looks of it too, but must admit I still have those in storage as my original rear mudflaps still are like new, and I just have the Entreq reinforcement brackets on those. Here is the Offroad Tec link to the product.
http://offroad-tec.de/shop/main_bigware_34...ems_id=158
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #413382 3rd Apr 2015 5:10am
LR90XS2011
ebay eBay Item No. 321708245826 DEFENDER 90 TDCI XS,
Post #413389 3rd Apr 2015 6:48am
williamthedog
Canberra Man wrote:
Steve E
Hi Steve ,as above but a non winch on mine, quality very good.Been fitted to mine for about 2 years and still looks as good as new. Thumbs Up
Post #413393 3rd Apr 2015 7:21am
SailingTom
Another vote for the Gwyn Lewis mudflap kits, available from Matt now.
Definitely the best mod ive done, had the front kit on my last 3 defenders and will get the rear kit they now offer at some stage. 10/ 10 and look so neat aswell as protecting the sides and outrigger.
Post #413394 3rd Apr 2015 7:21am
