|  | Home > Puma (Tdci) > 90 hard suspension |
| Gaz Member Since: 18 Jan 2015 Location: Midlands Posts: 34      |
 Hi all and happy easter,I have a 2012 2.2 90 hard top  and i am trying to make the suspension softer,i do not carry any big loads 99% is on tarmac.It is a 2550kg hd model,this comes with hd rear srings  NRC9662 and NRC9463   gr/yel/red and gr/yel /white.Ive swapped these for NRC 9448 and NRC9449  blue/red  and yel/white rated at 225lbs as fitted to the 2400kg model.i also fitted Bilstein B6 shocks just to the rear.This has made no differences what so ever.Its still rock hard and bouncy on my local potholed roads.Ive read loads of post on  this subject ,One person suggested fitting the standard front shocks to the rear ieNRC 9446 and NRC 9447 blue/yel and blue red.these are rated at 175lbs i think.Any ideas folks.Thanks in advance | ||
|  2nd Apr 2015 8:26am |
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000    | Can't find them at the moment - but you could consider fitting the 110/Disco front progressive onto the rear:
 110 Driver’s Front NRC 8044 Double White Stripes 384.30mm 110 Passenger Front NRC 8045 Double Yellow Stripes 368.10mm Double WHITE NRC8044 210lbs 7.5 15.13" L/F-Disco Double YELLOW NRC8045 210lbs 7.5 14.49" R/F-Disco 210 is only a bit down on the 225 rear firmest - but benefit from the progressive rate - might be worth checking the damping first though. If you have your old shocks - swap them back for a test drive. | ||
|  2nd Apr 2015 8:52am |
| Posting Rules
