Home > Technical > Horn won't stop sounding!!
dougelec
United Kingdom 2000 Defender 110 2.5 TD CSW Rioja Red
Just driving back from the shops in my 1990 Defender when the horn started sounding. I've pulled the relay and found a constant 12V on the coil. According to the Haynes manual circuit diagram sounding the horn from the stork doesn't go through the relay so I'm assuming it's something to do with the alarm but there's obviously no diagram. Does anyone have any ideas of what could causing this and are there any alarm circuit diagrams knocking about online?
Post #412973 1st Apr 2015 4:37pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
You sure its not a knackered Indicator/horn stalk?
Quite common for them to fuse out inside. Try unplugging it first to eliminate . Guns and Landrovers .... anything else is irrelevant.
Post #412974 1st Apr 2015 4:46pm
dougelec
Cheers for the reply. I can still sound the horn from the column switch with the relay removed but the horn sounds as soon as I replace it. There's a continuous 12V across the coil and I don't know where's it coming from.
Post #412976 1st Apr 2015 4:51pm
Romadog
Check battery is holding charge.
Is horn sound from alarm sounder under l/h wing. It goes off when its internal battery is Censored .
Replace with new, do not buy second hand .
Post #412985 1st Apr 2015 5:34pm
Romadog
Do you have an alarm ?
Post #412986 1st Apr 2015 5:35pm
Laurie
Horns usually have a permanent live connection and are switch by earthing the other connection through the horn switch. If that connection has frayed and is earthing elsewhere the horn will sound.
Post #412990 1st Apr 2015 5:39pm
dougelec
Cheers, Romadog. Yeah, the car has an alarm fitted. Are you saying the alarm unit in the LH wing has an internal battery? Any idea what type it is? Wasn't aware of this second sounder.........eeee, every day's a school day!!!!
Post #412992 1st Apr 2015 5:46pm
Romadog
Yes it has so if someone disconnects the main battery the alarm can still sound.
http://new.lrcat.com/#!/1228/841/10542/843/10552
Very embarrassing when driving out of Sainsburys and it goes off !! Embarassed
Post #412994 1st Apr 2015 5:51pm
dougelec
I know I'm going to sound as thick as a whale sandwich here but can you describe where this unit is exactly, please. Just been out for a quick look and can't find it.
Post #412996 1st Apr 2015 5:54pm
Romadog
behind headlight
Post #412999 1st Apr 2015 6:07pm
