Home > Puma (Tdci) > My Puma is trying to de-cat itself!
Page 2 of 3 <123>
To close this thread, I thought the following notes might be of some interest.
1) My thanks to the team at Alive, for stunningly good service! I am not sure who I spoke to (Gary, Alex, or someone else) but they were extremely helpful, and I ordered a front pipe mid-morning on Wednesday, it arrived mid-morning on Thursday, and was fitted by mid-morning on Friday. Many thanks, guys, if you read this! Thumbs Up
2) Replacing the broken cat pipe with a de-cat pipe has made two significant differences. Firstly the noise is quite different. There wasn't much 'leaky exhaust' noise from the engine with the cracked pipe, but there were general 'bag-of-nails' sounds and 'turbo-on-its-last-legs' rattles and whistles which were disturbing. They have now gone, and the engine generally is sweeter-sounding and seems smoother than ever. Secondly the performance from 2500 rpm upwards is transformed - whereas before the engine sounded as though it was objecting to revving to 3000 rpm, and I seldom did so, now it is smooth, sweet, and quiet to 3500 rpm (and possibly higher, but that's not how I drive it). The power is noticeably improved at these engine speeds too, with more power and a smoother delivery.
(Editted for spelling)
Post #412895 1st Apr 2015 9:32am
Thumbs Up I have my eye on the Alive exhusts too.
Gary got me out of a hole quick with some EGR problems I had last year too.
Post #412897 1st Apr 2015 9:45am
Would you of got any of the benefits of the de-cat pipe by just replacing a broken cat pipe with a new one though?
Post #412912 1st Apr 2015 10:35am
I can well imagine that the noise improvement would be the same, but it is hard to see how the performance increase would have resulted from a cat fitment. it is possible (back pressure and all that) but I doubt it. The performance difference is not earth-shattering but is noticeable.
Ultimately we won't find out until I take the decat off to refit a cat pipe when I find one at a sensible price.
Post #412917 1st Apr 2015 10:39am
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
On my mates stock puma, decat and air intake mod definatly made a difference not a placebo one for sure!
Post #412965 1st Apr 2015 3:16pm
K9F
K9F wrote:
It was in my view the cheapest performance enhancement and engine protection modification you could do next to EGR blanking.
Thumbs Up
You have removed the 'stranglehold' the cat had on the breatheability of your engine. Still stand by that statement above! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #412981 1st Apr 2015 5:25pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
+1 for cat removal, completley transformed mine Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #412988 1st Apr 2015 5:37pm
Maybe it's just the general age thing but it's only you guys with 2.4s whipping the cats out.
Post #413070 1st Apr 2015 9:48pm
K9F
TD5s and 2.4s yes cats are easily removed with no complications. 2.2s obviously don't have cats and apart from certain export models of 2.2s that do not have DPFs fitted I've yet to hear of a 2.2 Defender DPF removal in the uk. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #413085 1st Apr 2015 10:20pm
What makes you say that?
Post #413096 1st Apr 2015 10:38pm
K9F
From the downpipe rearwards the exhausts are exactly the same be it 2.2 or 2.4. The CAT on a 2.4 is not connected to the ECU and as such can be removed without any further implications or affects to the running. The DPF is a completely different kettle of fish.....a DPF is not the same as a Catalytic Convertor.
From the Alive website as an example......
This ALIVE Exhaust System does not come with a Decat Downpipe Section, as the Puma 2.2 TD4 Model is fitted with a Diesel Particulate Filter, which can not be removed.
http://www.alivetuning.com/alive-boutique/...duct_id=83
The difference between a DPF and Catalytic Convertor explained.....
http://filter.ezinemark.com/difference-bet...09b3d.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #413274 2nd Apr 2015 7:08pm
munch90
All or most dpf vehicles have a cat and dpf , most new ones are in one unit , some older vehicles in two separate units
saying that k9f , i knew what you ment Thumbs Up
There are some companys programming out the dpf in the ecu program /map , then you knock the centre out of dpf , not heard of any land rovers being done ( YET !! )
Post #413277 2nd Apr 2015 7:17pm
K9F
There's a van that conveniently parks outside several dealerships that are very close together near me with advertising on the side stating that they can offer 'a DPF removal service' I was wondering after last year February's MOT legislation regarding Cats and DPFs how their business was affected? Still appear to be parked there most days.
My point regarding DPF/Cat removal on a 2.2 was twofold. Those that do so on a TD5/2.4 find it an easy uncomplicated process. Not so on a 2.2 that's why nobody has done it as far as I know. There was discussion on the forum about the availability of south African ECUs fitting it and just binning the DPF off a 2.2 as a viable option sometime ago. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #413294 2nd Apr 2015 8:37pm
T1G UP
ignore my PM!
i have a 2.4 with both options of catted and de catted pipe.
2.2 pah!
Post #413296 2nd Apr 2015 8:43pm
But a 2.2 (UK spec) has both a cat & a dpf.
Post #413406 3rd Apr 2015 8:05am
Page 2 of 3 <123>
