Home > In Car Electronics > Nanocom vs Scangauge II vs Ultragauge
Eduardo
Hi guys!
After several years using my ODBII + Android app I think it is our to put a dedicated ODB2 reading system in the Defender.
I know that this matter has been discussed before several times. But still have some doubts
Nanocon cost a lot more than Scangauge II and UltraGauge (USD 500 vs 150 USD) but Im not sure if I need all the additional functions that it have (reading/write ECU, handle the alarm, ABS, etc).
On the other hand I'm not sure if Scangauge or Ultragauge can save some raw data for further analysis as my actual system using Torque do (appears that Nanocom can do that but Im not 100% sure).
Any other dedicated system in the market that can do that?
Cheers from Chile! Eduardo
Post #412383 30th Mar 2015 6:24pm
Anderzander
Eduardo - it might be only me who doesn't know this : but what model car do you have ?
Post #412398 30th Mar 2015 7:18pm
Venomator
Looking at his profile truck Eduardo has a 2008 110... Thumbs Up
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #412406 30th Mar 2015 7:29pm
Eduardo
Yep
110 SW MY2008 Mr. Green Eduardo
Post #412454 30th Mar 2015 9:03pm
Lorryman100
Post #412457 30th Mar 2015 9:08pm
Cheshire110
http://www.defender2.net/forum/topic33788....ultragauge Cheers, David
Post #412479 30th Mar 2015 9:31pm
Lorryman100
A point to remember when looking into these types of tools is that the clue is in the name, scan gauge and Ultra gauge. These are gauge tools monitoring the relevant PCM sensor addresses that each tool has addresses for. The Nanocom, MSV2, Hawkeye, GAP Diagnostic etc etc are diagnostic tools which allow, depending on model complete access to all the modules on the Puma including the ability to write new settings ie: Key Plip learn, Pilot correction and fuel pump learn etc. Some of the tools will display live data and allow you to save the readings to go over at your leisure so there is a big gap in capability between a gauge tool and a dedicated diagnostic tool. JMTW Thumbs Up
Post #412485 30th Mar 2015 9:39pm
Eduardo
Thanks Lorryman
I was looking for this post without luck Thumbs Up
Just one question arise to me:
Are Scangauge or Ultra Gauge able to store raw datas or just show it?
Cheers Eduardo
Post #412522 30th Mar 2015 10:22pm
Lorryman100
It just displays the raw data from the sensor address. Thumbs Up
Post #412529 30th Mar 2015 10:34pm
Eduardo
Evil or Very Mad
So...
The final decision is quite dificult. I need something that can store raw datas... Eduardo
Post #412552 30th Mar 2015 11:48pm
roel
A Nanocom can do that. Roel
2003 90 Td5 (2009-now)
Post #412581 31st Mar 2015 7:50am
Anderzander
The other obvious factor is mounting it - the scan gauge can be very neatly mounted as a permanent instrument.
Whereas the Nanocom is more realistically something to use on a temporary basis - particularly as leaving it in your car can pose a security risk.
Post #412614 31st Mar 2015 9:59am
Eduardo
What about this one?
http://www.auterraweb.com/dashdyno.html
Appear to be quite complete and at a very reasonable price
Or this one...
http://www.launchtechusa.com/assets/products/crp123.pdf Eduardo
Post #412777 31st Mar 2015 8:01pm
