Home > Puma (Tdci) > Oil Pump Recall for the Puma TDCi 2.2L EU5 - can anyone help
Page 3 of 3 <123
nidge n
Krissvdh wrote:
As requested.
Kris
Rework by krissvdh, on Flickr
So are we now saying that those of us with 2.2 should be changing their oil pump regardless of recall or not?
it looks like Ford have made amendments / upgraded the pump. i just wonder why LR are strangely quiet on this. For me,it makes sense to upgrade rather than risk a failure. Or am i being unnecessarily pessimistic Big Cry
Post #411835 28th Mar 2015 9:06pm
No just impatient... Wink
Post #411865 28th Mar 2015 10:10pm
GUM97
Just sit tight, and wait for LR Wink An engine to TDi for!
Post #411931 29th Mar 2015 9:22am
Krissvdh
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
It may not be the same pump. The pumps coming through in the rework kits are Peugeot Citroen marked units. I've not seen one of the take offs yet. I'll have a look when I do.
Kris
Post #412185 29th Mar 2015 9:46pm
johnnyd
Just caught this thread, can one easily tell which pump might be fitted?
JD 2008 TDCi 2.4 XS CSW
Post #412285 30th Mar 2015 12:16pm
munch90
no its inside sump
Post #412288 30th Mar 2015 12:19pm
johnnyd
Yikes.....Mine is 2008 and not under warranty anyway, whats the recommend here, has anyone changed theirs just as a safety measure is it 2.2 and 2.4 ?
Post #412289 30th Mar 2015 12:20pm
munch90
JD
no its inside
what year is yours ?
Post #412290 30th Mar 2015 12:20pm
munch90
johnnyd wrote:
Yikes.....Mine is 2008 and not under warranty anyway, whats the recommend here, has anyone changed theirs just as a safety measure ?
JD
yours is 2,4 not 2.2
only effects 2.2 euro5 onwards
Post #412291 30th Mar 2015 12:21pm
johnnyd
ah...relief .....thanks munch90
Post #412292 30th Mar 2015 12:23pm
"hot idle moan"
Just researching via the net on all things Ford and oil pump and had to share this one even though it's not 2.2 related:
http://www.exploroz.com/Forum/Topic/109727...ssues.aspx Shocked
Ford have produced a TSB that details a known problem, that they call, a "hot idle moan".
The problem is that oil pump and oil pickup pipe pulsations have been producing oil pan vibration.
The TSB details a modification that involves a new oil pan and a new oil pump pickup tube.
"Subject: P375 Ranger 3.2L Hot Idle Moan (Supersedes TSB 13-01-AP to include oil pick up tube)
Models Affected: 2012 Ranger with 3.2L PUMA engine
Markets Affected: E and G Markets
OASIS Symptom Codes: 448***, 4481**
Description: Some 2012 Rangers built between 8/29/2011 to 9/6/2012 and with a 3.2L puma engine may exhibit a hot idle moan noise coming from the engine oil pan area.
Root Cause(s):
Oil pump pulsations may be transmitted from the oil pump through the oil pick up tube onto the oil pan causing a moan noise.
Dealer Action:
A new oil pan and new oil pump inlet tube should be installed. The new oil pan design has a different stiffness and the oil pump pick-up tube has been revised to prevent vibrations from radiating the noise.
Service Procedure:
This procedure addresses noise in hot idle condition.
1. Is noise present during hot idle conditions or within 1 to 2 minutes after idling?
a. Yes – proceed to step 2.
b. No – This procedure does not apply. Proceed with normal diagnostics.
2. Remove and replace sump and oil pick-up tube with a new level part. Refer to 2012 Ranger Workshop Manual (WSM), SECTION 303-01C Engine - 3.2L Duratorq-TDCi (148kW/200PS) – Puma - Removal and Installation – Oil Pan
3. To install, reverse the removal procedure
4. Fill the oil pan with clean engine oil. Refer to: Specifications (303-01C Engine - 3.2L
Duratorq-TDCi (148kW/200PS) - Puma, Specifications)."
Post #412319 30th Mar 2015 1:27pm
GUM97
See here:
http://www.defender2.net/forum/topic36247.html An engine to TDi for!
Post #413315 2nd Apr 2015 9:17pm
Thumbs Up
Post #413436 3rd Apr 2015 10:27am
Page 3 of 3 <123
