![]() | Home > eBay & Bargain Spots > Twisted alloy wheels x5 on ebay |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Just spotted these might be of use as know lots on here like them
http://www.ebay.co.uk/itm/161650991829?_tr...EBIDX%3AIT |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I spotted them as well but am only interested in the 18" variety. If you look at picture 11 there looks to be a small flat spot in the rim at about 10 o clock? It could just be me but it does look a bit out of shape to me
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Good spot grafty
![]() Looks like you're right, on the 5th spoke at 10 o'clock it looks definitely looks like a damaged/flattened rim, I'll enquire. |
I'm glad im not the only one to see it. I'd be interested to hear the response
There is also a wheel that has a chalked 'B' at the one o' clock position on the tyre, that rim has a nick in it at the five o' clock position. Despite claiming the wheels have been powdercoated and not fitted I think they have been touched up too but not sure as it may be bead lube splatter? If you go through life with your head in the sand....all people will see is an ar5e!!
Seller has responded saying he's sure there's no damage but he's going to have a look and get back to me later.....
Here's the reply..... Hi Paul I had a look at that wheel this morning and your right it does appear to have a slight flat on the edge. I've just taken the wheels to be balanced and that one only needed a few weights so it must be running true. I don't know if it is from when the wheels were made as I purchased them second hand. Thanks Again .. well spotted grafty. It's a long way to go for me anyway to find problems and a have a wasted journey. ![]() |
