Home > Technical > Winch power advice
gumdrop
Winch power advice
Evening all,
Anyone know if you can get a 240v power supply to power a 3.8kw 12v winch. I want to try and run this winch without a battery out of the vehicle.
Cheers in advance. Cheers
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #411209 26th Mar 2015 8:37pm
munch90
No , to get the amps needed the transformer would be the size of a car ( roughly ) or very big in otherwords
Depending on what your using winch for , get a battery and use a anderson connector then charge battery after use with normal battery charger
what you using winch for ?
Post #411212 26th Mar 2015 8:47pm
Cupboard
How long are you trying to run it for?
I've seen one in a lifeboat station that's just got a battery powering the winch, and a small charger charging the battery.
the other option is one of the large mains powered battery charger/jump starter units. There are ones designed for trucks that will put out that sort of power, I know Sealey do some three phase ones, but this sort of thing may get you somewhere near where you need to go: https://www.machinemart.co.uk/shop/product/details/charger-2
I'd still put a battery in there too.
A 3.8kW winch won't always be drawing 3.8kW but when you are, that's about 300A. It also is unlikely to be rated to 3.8kW continuous.
Have you thought about just using a mains winch/hoist? And please note the difference Smile
Post #411225 26th Mar 2015 9:26pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Any information on what you need it for? Will it be in a vehicle / permanently mounted somewhere? or free standing?
Not even domestic household mains sockets support that amount of electric, you are looking at around 340 amps at 12v and around 16 amps at 240v (max domestic socket is 13amp. Using just a transformer would require a 32 amp round commercial / Caravan style socket to be install on site and the transformer would be extremely expensive / Large.
The cheapest setup would be a 100ah 12v battery and 1 or more 20amp chargers running from mains. 4 would give you 1min of winching for every 5 minutes of charging. 2 Chargers for 1min / 10min or 1 charger 1 / 20 etc..
Post #411226 26th Mar 2015 9:28pm
gumdrop
Thanks for the replies - using it to raise and lower the side of a 20ft container for a hair product roadshow - what's more the container is pink Shocked Think the best solution is either a 240v winch or use it with battery/charger set up, it will only be dropped and raised once a day. Cheers
Simon
50th D90 - my toy!
Post #411242 26th Mar 2015 10:01pm
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Post #411247 26th Mar 2015 10:10pm
martinfiattech
Wow, could you imagine the size / cost of the inverter to run that.
Looking at the at the power rating of your winch motor. It`s nearly twice the max power of your starter motor.
Which is roughly 2 to 2.5 kw`s.
My self I would get some good deep cycle batteries, with a large reserve capacity.
And good thick cables. ( welding earth cables are good for high amps at low volts). Excuse the spelling I`am better with spanners and wires.
Post #411248 26th Mar 2015 10:14pm
Don't forget that a 240V 13A socket is incapable of supplying 3.8kW - it's more than 13A. A 16A socket might, depending on cable length and losses.
Post #411252 26th Mar 2015 10:22pm
JWL
Could you not go hydraulic? Either winch wise or using rams. a hydraulic pump will provide more power with either a 12v pump or even a portable hydraulic power pack. There is even the possibility of using a hydraulic ram with a pulley on the end of the ram which will provide a winch type action, one end of the rope is fixed at the base of the ram and when you extend the ram it pulls the rope. This idea works on the same principle as a four post lift.
Post #411264 26th Mar 2015 10:34pm
Cupboard
If it's only raising/lowering the side of a container, that's not too difficult so I'd be looking at one of the many mains powered hoists on the market.
Post #411270 26th Mar 2015 10:55pm
