Home > Maintenance & Modifications > removing paint overspray
landlocked
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I've noticed some paint overspray on the car (white onto black and grey) Rolling Eyes
Does anybody know of a way to rectify this myself?? maybe clay bar?
Best Corris Grey 110 XS SW
Post #407589 14th Mar 2015 8:11pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
A drop of rubbing compound, G3 or similar,
T-cut will do it also, just take it steady.
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #407592 14th Mar 2015 8:14pm
V12vanquish
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Autoglym Super Resin or similar with a light cut might do the job. It will also give some protection as well as cleaning.
Post #407610 14th Mar 2015 9:23pm
LRI-Solutions
Agree with Ian use some G3 Thumbs Up LRI Solutions Ltd
www.lrisolutions.co.uk
Post #407612 14th Mar 2015 9:30pm
Green Machine
Clay can work to remove overspray, I've done it before and it worked well. Check out the Bilt Hamber clays - they are good and don't need a special lubricant, just water. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #407636 15th Mar 2015 12:26am
leonski
Morning,
Clay bar should work, depending on how heavy the overspray is!
I have just removed some from our brand new 110 and it worked a treat.
You can always start with the clay, which is the least harsh solution then move on to the G3....
Post #407650 15th Mar 2015 7:32am
Happyoldgit
Do it properly, G3 or T cut of you must then polish of your choice.
I mean if push comes to shove you could use toothpaste as it's generally slightly abrasive but as has been said G3 is really the way to go. Steve.
http://forums.lr4x4.com
Post #407758 15th Mar 2015 3:01pm
Griff_L322
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Clay bar with plenty of Lube then polish
Post #411203 26th Mar 2015 8:05pm
