Home > Td5 > Install TF110 - Terrafirma extra wide wheel arches |
Bosken Member Since: 06 Sep 2014 Location: In the bush Posts: 19 |
Pix. As you can see the OEM arches have extra plastic to cover the gaps. TF110 arches does not
Sure, i can use a jigsaw and trim the old ones, but really? Click image to enlarge Click image to enlarge |
26th Mar 2015 2:19pm |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 |
You can either trim the original spats so they are flush with the bodywork, or trim them so they fit flush inside the terrafirma spats. To be honest I wouldn't fit them, they are bloody awful things, IMHO.poor quality, poor fitting and you have to drill the body panels. The better option is to fit the rubber strips that fit onto the original spats.
26th Mar 2015 7:32pm |
Agree, not the nicest parts out there. Live in Spain and must have them to be able to register it with all non-stock parts for spanish"MOT".
Itīs a nightmare down here with modified vehicles. Did as you said, trimmed the stock front arches and all mounted. Click image to enlarge |
26th Mar 2015 8:52pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Not a fan of them either a bit Heath Robinson But Ive heard the Spanish MOT is a nightmare.
26th Mar 2015 8:56pm |
Unless you're driving on a bottomless bog on a regular basis:
Step one: put extra wide wheel arches in bin. Step two: put extra wide tyres in bin. Step three: fit narrower tyres that won't cover everything in mud, will improve your turning circle, will cost less, will get your further and doesn't involve ruining a perfectly lovely Land Rover. End of mutterings from an opinionated sod that doesn't like wide wheels. Your Land Rover, have fun with it |
26th Mar 2015 9:45pm |
As long as you are sorted out and happy. My advice would also be to buy some decent stainless steel fixings and bin the screws supplied, also put a spot of waxoyl or ACF 50 on all the drilled holes to keep any moisture out, then if you go back to standard you can but some colour coded pop rivets in the holes with no blistering paint around them. |
26th Mar 2015 9:53pm |
Just want to show you guys how it looked when i picked it up last year, Even inside itīs 10 times better. Was a nightmare. Great price approx 4000Ģ for a 2001 with 150.000km.
I like the wheels i have no complains on them. Guess i will find out when we are going to Marocco later Click image to enlarge |
26th Mar 2015 11:05pm |
Yes, will follow your advice, I am replacing all screws and bots with stainless everywhere. |
26th Mar 2015 11:07pm |
But me and my buddy ahd a blast this weekend. Rain in Spain means play
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
26th Mar 2015 11:12pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Do you have info on the mentioned rubber strips? I like that idea. Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
27th Mar 2015 9:49am |
