Home > Maintenance & Modifications > Terrafirma Defender Td4 de-cat down pipe
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Does someone is using the Td4 de-cat down pipe from Terrafirma??
It can be integrated with the silencer replacement pipe Matteo
Defender 110 Td4 SE MY 09
Post #41117 23rd Sep 2010 8:03am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Bomber, I've got the D cat pipe and mid box replacement on mine they fitted really easy... but i got mine from here
http://www.td5alive.com/exhausts.php really nice chap really helpful and also a site sponsor Thumbs Up
Also made of Premium T304 grade Stainless Steel not the cheaper 409 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41145 23rd Sep 2010 3:35pm
AndrewS
Get my pipes from BAS
http://bellautoservices.co.uk/ 130's have feeling's as well you know Smile
Post #41146 23rd Sep 2010 3:37pm
K9F
When you click link via products to decat exhaust nowt happens? Are they stealth pipes??? Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41152 23rd Sep 2010 4:52pm
Bomber82
Rolling with laughter Rolling with laughter Rolling with laughter Matteo
Post #41154 23rd Sep 2010 5:26pm
Bomber82
Fakete you take the sport exhaust complete or only the midle part?
The sound and the performance changes? Matteo
Post #41157 23rd Sep 2010 5:32pm
Bomber82
Thanks Andrews,I've send a mail to Pete! Thumbs Up
Could you give me your feedback? Matteo
Post #41158 23rd Sep 2010 5:33pm
K9F
Bomber,
When firtting the decat pipe I believe you have to unbolt a cross member and the prop shaft to get it to fit or cut the old exhaust out...
JMS wrote:
Driver,
I fitted one last weekend and i have found the results to be very good.
I am currently running with the most recent Land Rover ECU software (as of 4th June) ITG air filter and Alive SS pipe and de-cat.
Fitting was not to much of an issue except if you want to keep the old CAT in one piece. Its huge and to remove it without cutting i had to un-bolt the prop shaft at the front diff and the chassis cross member. Other than that easy.... Rolling with laughter
I found the engine runs quieter, turbo runs much smoother and quite possible getting a few more MPG (will do a tally up on the next re-fill)
Hope this helps.
JMS
See here:
http://www.defender2.net/forum/topic3204.html?highlight=cat If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41159 23rd Sep 2010 5:36pm
fekete
Hi mate, i took just the D Cat down pipe and mid section only and the sound is nice... not much louder than standard but you hear the turbo whistle and it pulls a little better Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41164 23rd Sep 2010 6:25pm
Has anyone got the silencer replacement pipe only? http://cgi.ebay.co.uk/Terrafirma-silencer-...4aa2fbf78e And also is it just unbolt orininal and bolt in the replacement pipe to fit?
Post #41421 27th Sep 2010 9:13pm
fekete
Yes its a straight fit unbolt and just fit..get your pipe from here
site sponsor really helpful fast delivery Thumbs Up
EDIT Make sure you get new bolts Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41422 27th Sep 2010 9:18pm
Brill, only thing is they seem to do systems only aswell as D cats but i can't see any silencer replacement pipes on it's own
Post #41423 27th Sep 2010 9:29pm
fekete
Just bell him they have them that's were i got mine from you will get a little bit of if you mention this site Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41425 27th Sep 2010 9:51pm
Alive Tuning
Forum members always get a good discount! Best way to buy is to call us on 01472 812900 and we'll process your order manually, applying discount too.
We don't list the mid silencer replacement pipes on out website, but we do have them in stock. Will get round to updating the shop soon. Embarassed
Note: We do 304 Grade decat pipes (the real deal!) which are exclusive to us, and also the cheaper 409 grade decats, which you can buy from many sources, including those mentioned on here. Whistle
Post #41502 28th Sep 2010 10:48pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
try here www.IRBdevelopments.com Putting Dreams on Drives at JLR Solihull..
Post #41552 29th Sep 2010 2:51pm
