![]() | Home > Maintenance & Modifications > Steering wheel advice |
think the easy way is if dsc fitted , then you need a special/different boss because off the steering angel sensor fitted below the wheel
As munch90 says
Griff_L322 Member Since: 26 Mar 2015 Location: North Wales Posts: 89 ![]() ![]() ![]() |
Yes, with a June 15 HT XS 90 on its way also looking at a new steering wheel we want the slimest boss and momo wheel not sure which one yet, the bowler tested was very nice from Conway LR
Rudski Member Since: 13 Jul 2014 Location: Lake District Posts: 141 ![]() |
Thanks guys,
I thought it was to do with wheel spin and yaw picked up with sensors on the vehicle, I didn't realise that the steering had a sensor aswell. So if I'm picking this up right as long as I get the correct boss I can still get the steering wheel and snap off boss that I want ![]() Does it cause any problems with the fitting, special tools etc ![]() Thanks again for the replies ![]() |
5 POT Member Since: 24 Nov 2014 Location: UK Posts: 81 ![]() ![]() ![]() |
Nitram on here used a similar set up but a Momo Millenium and Twisted Slim line boss with a snap off quick release.
As long as the boss is 15MY for DSC there is no extra tools needed for fitting. |
Thanks 5 pot
I've just found the info from bolt on bits, just need to keep away from the collar sensor adjacent to the steering wheel. ![]() Once again excellent feedback ![]() |
Iv'e just spoken to twisted. A very helpful chap with regards to this DSC issue.
They have manufactured a slimline boss approximately 25mm thick, this is fitted with the millenium sport wheel But they seem to think there might be an issue fitting the snap off system because of a lip on the boss, has anybody on here overcome this or used their system ![]() They have said a customer had to adapt it using a bigger washer to allow fitment was it anyone on here ![]() Cheers Mark |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
it was me....the twisted is the slimmest on the market but only combined with a mono millennium wheel.
I combined it with a Murray snap off it is great but expensive......but we'll worth it......the Murray snap of does not directly fit the boss but it is easily sorted ------i got mine machined to fit but you could use a washer to raise the wider part of the boss so as to make it flat to fit the snap off. or you can simply file it down flat with a grinder.......its only there to position the wheel but as the wheel is firmly secured by the screws you don't need it .....also your snap off may fit as its just a quirk of the murray one that causes a problem........... I'm at work now soand using a tablet so the quality of this post could be better.....look at my posts or lorrymans or gilarians. for a rounded picture .....I'm out tonight. but if you want to pm me for any info I will try to help.....its deffo the thinnest setup if your using a snap off and the twisted boss. could not be made any thinner imo. and the snap off is play free up to now! |
Thanks nitram
Yes it seems twisted is the thinnest out there but as you say it has a lip that fouls the snap off system, I'm waiting for Land Rover solutions to call back with their dimensions for the boss they supply, obviously not as thin as twisted kit but quite a bit cheaper and hopefully a straight bolt up job without extra work. Thanks for the reply ![]() Cheers mark |
Have a look here for some more pics of the twisted boss and murray snap off !
http://www.defender2.net/forum/topic34822.html |
