![]() | Home > Maintenance & Modifications > Front Spring Advice |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Afternoon all,
I currently have some fairly new genuine front springs on my 110 (110 USW spec ones). However with the matching ones on the back, it already looks very nose down (almost 45mm using tape measure). I know this is fairly standard with them, however I rarely carry large loads in the back but dont want to lower the back either. The 255/85R16 tyres are already tight enough for space. I would like to lift the front a little to make it look a bit more level. Was thinking of a pair of Gwynn Lewis 1"/1,5" packers for the front. However I am about to fit a fairly large front bumper and winch (First Four bumper with Husky winch) and I am concious that the front will be even more nose down. Therefore I am looking for a reccomendation for some new front springs to even things up a little. Quite happy with the ride quality as it is so dont want some silly mega HD springs that barely ever move. Anyone advise, i have been looking at the Flatdog ones. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
famous four hd +1"
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Why not pop some Disco2 front spring isolators in the top and a defender 90 rear isolator at the bottom.
Will take the height up and reduce road noise ? http://www.paddockspares.com/rbc100111-isolator.html http://www.paddockspares.com/anr2938-rear-...om-ja.html |
Cheers,
I should have said, I currently have the ANR2938 spring isolators on the front springs. Not come across the Disco2 ones used before though, how to they fit? Also I have checked and both my front springs are Yellow/Yellow striped Steve 02' 110 TD5 Double Cab Rebuild Thread |
they replace the turret ring.
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
Im fitting standard 90 rear springs to mine, they're the factory '110 front HD' springs so will level it up a bit and take the weight of the gubbins bolted to the front without sagging too much. Pete
2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Are those the same as 130 standard front springs?
