Home > Technical > Recovery points
Page 1 of 3 123>
rick
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Recovery points
Hi,
I'm just wondering where you're all placing your recovery points on your Defenders and also, what kind of recovery points are you using?
My basic concern is that sooner or later I'll get stuck in deep, soft sand. While I have a shovel and a pair of 'Max Trax' to get me out of most trouble spots, I know that I'm living on borrowed time.
Strangely, our local 4WD specialists don't seem to have anything for Defenders...
2 chuckled that Land Rover's don't seem to get bogged and so no one's ever asked them before;
1 suggested I use the tie-down points (with a bow shackle); and finally
my local Land Rover dealer had no idea what Defender owners were doing on that front (a blank stare)
Does anyone have any ideas? I feel like I'm missing something. Any advice would be appreciated.
Cheers,
Rick. 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
2015 Discovery Sport
Post #41029 22nd Sep 2010 6:54am
K9F
There are a myriad of choices and applications, depends really on what you do and the likelihood of you getting stuck, Dixon Bate make good quality products maybe they have something suitable for your needs???
http://www.dixonbate.co.uk/Towing/tow_jaws.asp If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41033 22nd Sep 2010 7:10am
bob neville
Fitted a bumper with recovery points on the front and a 2" receiver on the rear which has a detachable recovery point. Shackles fit on both.
This is the front, no pictures of the back.
This thread shows the the rear recovery point (Andrews's pictures)
http://www.defender2.net/forum/topic2922.html?highlight=receiver
Bob
Post #41039 22nd Sep 2010 8:27am
leeds
Re: Recovery points
Cheers,
Rick.
The lash down eye is not designed for recovery applications
You can fit a JATE ring there in place of the lash down eye
With a standard bumper you can fit an Equipe type bracket and swivel recovery eye. These slide over the front bumper and utilises the bumper bolt holes
Winch bumper with built in recovery eyes
Steering guard with recovery eyes
Rear 2" receiver
Lots of possibilites
Avoid el cheapo ebay specials like the plague.
hth
brendan
Post #41041 22nd Sep 2010 9:08am
AndrewS
As mentioned above Thumbs Up
Get the best you can afford but make sure its rated. 130's have feeling's as well you know Smile
Post #41049 22nd Sep 2010 11:15am
mse
Dixon Bate on the rear using the NAS step tow - i did have a swivel eye mounted to the cross memeber
On the front I use the integral winch bumper recovery eyes. Mike
Post #41068 22nd Sep 2010 4:49pm
jst
i use:
dixon bate combined tow ball and jaw or a southdown towing eye on both mounted to a Southdown Tow pack.
Southdown front HD non winch bumper front with built in recovery eyes.
or i use JATE rings, if you do buy JATE rings get ones that are wide enough to take a steering guard. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #41074 22nd Sep 2010 5:59pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
jst wrote:
i use:
Could you point me at some wide ones? I bought some of the forged ones from Devon4x4 for the rear but I have a 2" receiver with brackets back to the chassis and the Jate rings won't go round them both Big Cry
The front is sorted (incorporated into the steering guard) but I'd quite like something on the back. Before someone states the obvious, I do have a shackle attachment for the 2" but I want something to attach a breakaway line for my Sankey.
Cheers One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #46048 23rd Nov 2010 5:33pm
BigMike
I have one of these http://www.qtservices.co.uk/parts/defender...ackle.html
Actually thats not going to help you (alan) because of your tow ball, but i ll leave it up anyway in case anyone else is interested. the rating is 8 tonnes from memory (assuming the back plate is used)
Post #46051 23rd Nov 2010 5:59pm
leeds
This is what happens if you use a lash down eye for recoveries
A couple of examples how NOT to use shackles
The WLL of a shackle is reduced by 50% when badly loaded
In the middle photo someone obviously does not know that a chain is only as strong as its weakest link!
Bottom photo, ignoring the strength of tow ball at 3.5 tonnes and should they be used in recoveries, why use the shackle??
Keep number of components to a minimum!
Brendan
Post #46059 23rd Nov 2010 7:59pm
Depends on what front bumper you have, but if yours is a plain standard type, or you've got a basic 8274 or husky bumper, then you can fit the D rings:
which are very good, strong, and look nice and "classic"
On the front of my 110, with an BRB bar (very similar to an ARB bar), i've fitted a pair of plain tow jaws,
These exact ones:
On the back end, depending on what towing system you use, you can fit a NATO hitch (strong) or one of the plain jaws as above, or a stronger 4 bolt dixon bate jaw, thus:
As well as the JATE rings as mentioned above. Trouble with JATE rngs are that if you get bogged and sink up to your bumpers in poo, you've got to grovel around to find them (unless you attach a rope/cable prior to venturing out)
Post #46060 23rd Nov 2010 8:02pm
BigMike
that towball / shackle combo is terrifying. tell me that's been put on there as a how not to do it, and not a shot of an actual recovery?
Post #46061 23rd Nov 2010 8:12pm
leeds
ALL three photos are actual real life photos and are not staged photos!
I have some 'interesting' photos of how NOT to do things. One of my 'favourite' shots is of a LR jacked up on a high lift jack, head under wheel arch, braying seven bells of hell out of hub assembly with a lump hammer. He REFUSED offer of a folding axle stand. That was the way they always did it!
You can tell people what is good practise but I also think it is important to show bad practice and explain why it is bad practice
Brendan
Post #46063 23rd Nov 2010 8:41pm
KarlB
Australia 2010 Defender 90 Puma 2.4 XS CSW Rimini Red
If you don't have a winch bumper or some very strong bullbar at the font with inbuilt recover points best option for the front is a pair of jate rings (forged ones are the best). If your vehicle is a D110, then you can easily fit a pair to the rear as well. The jate rings would replace the current lashing eyes and utilise the holes currently used by the lashing eye bolts. Fitting jate rings to the rear of a D90 is not as simple because of the fuel tank and the best way to fit them would require removing the tank first. The alternative for the rear is the use an Australian approved towbar with recovery receiver hitch. This is what I have opted for with my D90. Note that the towing equipment options illustrated on the Land Rover UK website for example, do not comply with the necessary Australian standards and cannot be legally used for towing on a public road (in Au). Also note that you should always use a bridle for any jate ring recover actions.
KarlB
Canberra
Smile
Post #46293 25th Nov 2010 11:36am
Lorryman100
An Aussie stockman and his wife had just got married and found a nice hotel
For their wedding night. The man approached the front desk and asked for a Room.
He said, 'We're on our honeymoon and we need a nice room, with a good strong Bed."
The clerk winked, 'You want the 'Bridal'?'
The drover reflected on this for a moment and then replied, "Nah, I reckon Not.
I'll just hold onto her ears until she gets used to it."
Sorry ........nothing to do with the thread, just couldn't resist posting Whistle
Post #49932 27th Dec 2010 10:57pm
Page 1 of 3 123>
