Home > Puma (Tdci) > Oil pump question
Page 6 of 6 <123456
munch90
Sump and timing cover off
Post #410331 23rd Mar 2015 9:57pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've not had the joys of doing one in a defender yet, only transits and peugeots,
Reasonably straight forward job to do,
Don't know about you Munch but sometimes I find the front covers either fall off, or are literally welded to the block!? Rolling Eyes 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #410348 23rd Mar 2015 10:11pm
munch90
Carful all round with sharp knife or if in a hurry bent it off and buy a new one
any bends in it and there is a good chance it will leak
Post #410371 23rd Mar 2015 10:39pm
munch90
I think the best thing to do with any dpf eqquipped vehicle is to check oil level at least weekly and if you find a rise in level then there is diesel getting in the oil from regen
Post #410375 23rd Mar 2015 10:45pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
munch90 wrote:
something of the net as well
Engine oils are subjected to a series of industry standard engine dynamometer tests to measure their wear protection capability, sludge and varnish formation tendencies, and fuel efficiency among several other performance attributes before they are approved for use in customer engines. However, these performance attributes are measured at the end of tests and therefore, do not provide any information on how the properties have changed during the tests. In one of our previous studies it was observed that engine oil samples collected from fleet vehicles after 12,000 mile drain interval showed 10-15% lower friction and more importantly, an order of magnitude lower wear rate than those of fresh oils. It was also observed that the composition of the tribochemical films formed was quite different on the surface tested with the drain oils from those formed with fresh oils. The objective of this investigation is to demonstrate how the friction and wear performance changed with oil drain intervals. A fleet of three vehicles was run in Las Vegas and oil samples were collected at various drain intervals from 3,000 miles to 15,000 miles. As in the previous study, the results showed that the aged engine oils provide lower friction and much improved wear protection capability. These improvements were observed as early as the 3,000 mile drain interval and continued to the 15,000 mile drain interval. The composition of tribochemical films formed on the surface with the 3,000 mile drain interval is similar to that formed with the 12,000 mile drain interval as seen before. These findings could be an enabler for achieving longer drain interval although several other factors must to be considered.
and I can Google as much stating the opposite
I wonder why F1 cars, GP bikes don'tuse old oil but fresh oil every race. I now when my mates and I raced bikes we always used new oil
You change oil when you want and I'll change mine every 6000 miles
Post #410379 23rd Mar 2015 10:49pm
I had thought of that but then what if you are burning an equivalent volume of oil over the same period?
Post #410478 24th Mar 2015 11:50am
What Happens If You Don't Change Oil For 84k miles
Post #410557 24th Mar 2015 5:23pm
munch90
I know what you mean but the 2.2 shouldnt really burn oil
any ones 2.2 burn oil ?
Also if the oil looks to be thinner then normal
Post #410606 24th Mar 2015 8:34pm
http://www.defender2.net/forum/topic35715....onsumption
Post #410721 25th Mar 2015 9:56am
Page 6 of 6 <123456
