Home > Tdi > Wiring diagram 1993 90, 200TDi
Gazngoz
Learned Ones,
I seek counsel. I have just bought a 93 90. Very happy bear. It came with a Haynes joke book. I have been looking at the centre dash ( where you would normally find the clock, rear wash wipe and cigarette lighter ) but can't match up any of the wiring with the wiring diagram in the Haynes manual. Only the lighter socket is still there but the green and black leads connected to it aren't shown in the Haynes. Similarly there are strange plugs on what I take is the old radio harness - certainly not ISO fittings.
I have attached a couple of pics below. Can anyone point me in the direction of a wiring diagram that relates to this wiring please.
I tried searching the forum but couldn't find anything related. Apologies if I have missed something obvious.
Thanks in anticipation
Gaz
Post #409968 22nd Mar 2015 7:40pm
Fatboy Slim
Wales
From memory the purple is a permanent +12V and the white is an ignition switched +12V
Post #409970 22nd Mar 2015 8:01pm
Gazngoz
Excellent thanks. Multi-meter confirms purple is permanent +12v. There's an awful lot of brown wires back there - anyone any idea on those please ?
Post #410005 22nd Mar 2015 9:15pm
shaggydog
Brown is live from battery un-fused/switched from memory but not necessarily plugged in at the other end to anything.
200Tdi's never had Iso plugs from new so you would have to wire them in yourself.
If you can hang on till tomorrow I can have a look at mine and send a proper photo of how mine is wired Thumbs Up
I have a similar wireing behind mine- yet to find a use for it!
 Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #410022 22nd Mar 2015 9:42pm
Gazngoz
Shaggydog,
That would be great thanks for your time
Gaz
Post #410048 22nd Mar 2015 10:40pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Lots of wiring on the engine side of the bulkhead I noticed wonder what they had in mind?
Post #410141 23rd Mar 2015 1:06pm
shaggydog
Here are the photos, Hope they help somewhat!
With regards the extra plugs and wires, I seem to remember reading somewhere that the 200Tdi loom was a modified TD loom so has lots of plugs and bits left over from when it was just a TD.
These then got cleaned up and away with the 300Tdi as well as better plugs and more dedicated looms. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #410270 23rd Mar 2015 7:57pm
Gazngoz
Shaggydog,
Superb mate thanks. The more I look at my loom the more credible the ex-TD loom sounds Smile
Think I'm going to split the "plug" containing the permanent and switched +12v that I think was for the original radio and use those feeds for my clock and possibly later a stereo. Don't have all the wires you have shown there.
Thanks again for your help.
G
Post #410329 23rd Mar 2015 9:54pm
Gazngoz
Shaggy,
On your pics above you have cig lighter on LHS, what I assume is a clock in the middle but what is it in the RHS position ?
Got some sound deadening in and the dash lower - just got to sort out the wiring. Touch wood, looking good !
Thanks for your help
Gaz
Post #446681 17th Aug 2015 8:16am
shaggydog
Yes you are correct Thumbs Up
Cigar lighter, Clock, Rear Wash Wiper (if fitted)
You will have to stick some photos up as it sounds like its coming on well Very Happy
Hope it helps Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #446744 17th Aug 2015 12:33pm
