![]() | Home > Wheels & Tyres > 265/65/18 spare wheel on standard mount |
No holes to drill on a Safai Equipment Single Pivot Swing Away....
![]() ![]() Click image to enlarge Your entire weight is on the back door. Any slight play in it will exacerbate the sound. Check your striker plate for adjustment would be my advice. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
That's is a rather large spare wheel haha!!! Got a link to that single point carrier?
Yes that was the first thing I checked. I've been over it a few times but figure there just be done secret I don't know as so many people run those wheels and tyres on standard carrier! |
Just looked them up and while the idea is good I'm not keen on the wheel basically blocking the window, sure that's a pain when reversing!
Carrying too much weight on the door and you can split the seam/welds on the door itself. There is a thread somewhere on it.
It is only a 90, reversing is not an issue. Just reverse until the car behind you alarm goes off...... ![]() Seriously after having my windows tinted I could see nothing through the rearview mirror for about 5 years due to the reflective properties of the tint film applied. I recently swapped the glass for a new tinted version from VGS where the glass itself is tinted and can see far more now than I ever could before. Anything close you can see through the spokes easily. ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 22nd Mar 2015 9:42pm. Edited 1 time in total |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
If it rattles ? something must be loose then ?? 18" Bowler on the standard Mount,, no rattles ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
What offset are the bowlers? Did you have to adjust studs so the wheel cleared the wiper arm?
8x18,, can not remember the offset,, would have to check
But were a simple straight fit, and guessing, a bit lighter that the 255/85 16 BFG MT on a Terra Firma wheel California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Found this....also had a 'rattle'....as mentioned striker plate would be the first place I'd be checking.
![]() http://www.defender2.net/forum/topic27939....door+split If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
