![]() | Home > Technical > Rear Shockers 2001 TD5 |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 ![]() ![]() ![]() |
Hi Folks,
I have the original LR heavy duty suspension / twin shocks at front and rear of the coil spring on the rear of my 110. The drivers side shocker has packed up, it is the rear of the two. My question is do I need to replace both (i.e. the rear two off side and near side) or all four. If so what shockers would you recommend, I don't do any towing, no seats in the rear. However is has an internal 8 point Performance and Protection roll cage, which I would imagine is a heavy beast. Thanks in advance ![]() Last edited by GSLRO on 19th Mar 2015 9:37pm. Edited 2 times in total |
You lost an 'h'.
Cos the spell checker on my tablet does its utmost to pi$$ me off
![]() Thank you ![]() |
All four IMHO....
Best code of practice is that whatever you do to one side of the suspension/rolling gear you must do to the other. I learnt the hard way as the stresses caused the other side to go shortly afterwards. From an old thread..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Front and Rear 6 shock absorbers
![]() Will have a look at the terafirma shockers Thanks for the replies ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20921 ![]() ![]() |
What Mal said above, pairs front or rear or all four.
Ideally all four unless they are only a few K in miles between them but in all honestly pairs should be fine. |
Taking your trip into consideration I think you are wise.
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
May be the 4 rears this month and the front 2 next month
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 ![]() ![]() ![]() |
All four being done next Friday, new shocks and springs for my 10 year old Defender 90!
Andy Defender Td5 XS90 |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Just out of interest Andy, what are you replacing them with? (Sorry for the hijack GS) 2005 Td5 | 90 Station Wagon | Tonga Green
Something different.
Maxtrac shock absorbers and standard Land Rover springs. Over the weekend I'll start a new thread with some pictures of them as don't think I've heard of any one using them before. Andy Defender Td5 XS90 |
4 rears ordered Terrafirma All Terrain TF 117s ... now where is that can of Plus Gas
Purchased and awaiting fitting 4 x All Terrain's for the rear and 2 x Big Bore for the front. Hope it makes a little bit of a difference
