Home > Maintenance & Modifications > Td5 Aircon unit removal?
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Been having a look at what I'd need to remove to get enough access to put down some dynamat in the front of the 90 and it looks as though the plastic aircon fan unit would have to be removed from the dash. Specifically for the passenger side as it extends down the bulkhead to the footwell floor.
It doesn't seem obvious how this is removed however. Is it relatively straight forward, a few bolts then lift out in one piece? Also is there any plumbing that needs disconnecting and subsequently recharging the system or is the removal of this unit a "dry" job?
Hoping I'm just being a bit blind and missing something obvious!
Post #408885 19th Mar 2015 7:16am
