|  | Home > Puma (Tdci) > Coolant drain? |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | Fuel cooler     There are a couple of blue connectors (might be black) but they are the lowest point, then take the top off the expansion tank and run water in until it comes out clear. Next step fill with specified amount of antifreeze (Texaco) then top up with water Probably want to run the engine before to clear the radiator and after to get the correct level | ||
|  18th Mar 2015 3:46pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Prior to asking i looked at the fuel cooler and i think there was six pipes, all of which looked the same and none were as hot as the rad hoses. How to they come off?
 TIA. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  18th Mar 2015 4:30pm |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | There's 4 pipes, bottom 2 are coolant    | ||
|  18th Mar 2015 5:43pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Thanks bpman... How do they detatch? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  18th Mar 2015 5:51pm |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | Probably best if you download the PDFs manuals from dgardel, all the info and safety tips included    | ||
|  18th Mar 2015 6:54pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | The pipe connections  have me stumped.... is there a special tool? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  19th Mar 2015 1:58pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | on the rasied lip round the end of pipe there is a bit you push in
 push pipe on slightly on push bit then should pull off | ||
|  19th Mar 2015 2:20pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Jeeze.... anyone got a link? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  19th Mar 2015 6:58pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | Sorry but they are easy to get off
 on the raised lip on the connector that goes on to the cooler , part of the raised lip pushes in to release the connector , push the bit before pulling the connector push bit then pull gently only thing sometimes is the connector can get packed with dirt making them bit harder to remove Try giving them a blast with wd40 aerosol straw in the end to wash dirt out | ||
|  19th Mar 2015 7:29pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Thanks... will give it another go in the morning. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  19th Mar 2015 7:50pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | Here's the "how to" for the Quick Release Pipes.  It's shows the Fuel ones, but they are similar for the coolant;
   Click image to enlarge Here's the drain and refill procedure from the workshop manual;   Click image to enlarge   Click image to enlarge   Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  19th Mar 2015 11:37pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Many thanks.... will give it a try in the apre' eclipse... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  19th Mar 2015 11:56pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Mission accomplished but you really have to tug at the pipes to get them off! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  20th Mar 2015 10:08pm |
| Posting Rules
