![]() | Home > Technical > Shell Fuel Save Fuels |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i did fill up for a long run which is when i usually get my best mpg and found i got 28 and a bit mpg which is what i get around town, did do a bit of low range off roading on that tank but only a couple of hours, did not do what it says but there still the cheapest around so i will still be using it.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Always use shell or total but never bother checking mpg but the total seems to last longer..
I don't really see differences in quality fuels, the cheap fuels are giving less mpg specially with my D3G4 V8.
I think that in Germany the fuel quality is also not that good as my mpg goes really down as soon as I cross the border between The Netherlands and Germany. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Well I only use shell and am struggling to get even 300 miles out of a fuller than full tank!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
There is a difference in fuels - certainly supermarket to main brands (shell/bp) but where as 300 is a bad tank - with the so called fuel saver this seems to be around the standard in the 90 not the exception.
Im sad so when tracking money I can easily track MPG, mileage etc and do - a quick history check show 28-29 is the average, the last few with fuel saver have been 25 this is just the 90 similar story with the other 3 ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
BP/Shell is adding seawater to their fuel
![]() ............................................................. Earth first. Other planets later |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
I've used Shell since Big Black was new (except once when I filled up with Asda - bleurgh - and when I was abroad) and averaged around 30 to the gallon. There has been a slight drop since the Fuel Save fuel was introduced though, but only by about 1mpg.
Will keep checking though... I'm quite sad when it comes to my MPG ![]() |
come on guys who gives a
![]() ![]() Only joking Karlos, it was a bit rich coming from someone who is too fat for River Island! Somebody else pointed out not was I only too fat but too old too! ![]() Treat every day as if it is your last....one day you will be right!! |
...found a fish in my tank wearing a green and yellow jumper ![]() 1968 1/32 scale Britains 109 Pick up. |
Well now that Shell is getting rid of the Brents (Alpha, Bravo, Charlie & Delta) they've got to find some way to cover the decommissioining costs!! ![]() ![]() |
Just because you drive a land rover shouldnt mean you accept poor fuel economy - certainly in the current times. Second...MPG is a good indicator of issues with the car third...i like to get what i pay for, if i pay for 1l better - i dont expect worse! Mike |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Same as that!! ![]() ![]() |
