Home > Wheels & Tyres > Balancing Issues and Beads
Page 2 of 3 <123>
K9F
I had my Mach 5s spun without tyres on after I got them to ensure they were straight and true. As you stated one of your wheels/tyre does not sound right with over half a pound of weight in old money stuck to it. The beads wouldn't have stood a chance.
I am still hopeful that the Dynabeads and the fact I have checked the wheels prior to tyre fitting they will be a satifactory combination.
Ken from the forum also kindly offered to balance mine but time and distance precludes this. With a dedicated fitter/balancer anything is possible but they are I think in very short supply. The stickies on my old Mach 5s look a dreadful mess having been on the rims for 5 years now. I will remove them and either get them rebalanced or replace with beads if this set pans out and the old wheels go back on.
Glad you are sorted. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408076 16th Mar 2015 4:00pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Good luck,
I'll be watching your thread for an update as I really did think they would work Smile Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #408078 16th Mar 2015 4:02pm
K9F
Having spoken to Colin at Dynabeads on two occasions he convinced me they would indeed work. We shall see, but on my other thread there seems to be good feedback on larger tyres such as BFG, Mickey Thompsons and Simex. Lorryman had an issue where he needed to fit more beads and Lambley had similar issues to yourself. Nowt to lose as I have the beads and wheels ready to go but am just waiting on tyre delivery now. Hopefully tomorrow!
Post #408085 16th Mar 2015 4:19pm
ozzie1989
Don't forget lots of pics please Very Happy Laughing Now: 2010 2.4 TDCi 110 Utility Wagon
Post #408086 16th Mar 2015 4:25pm
roel
I use this http://www.rematiptop.com/parts.php?sid=35 in my BFG 235-85-16 from the start and inside tubes. Laughing
I love it. Hardly any vibrations even after off-roading.
Still have to put them in my Simexes. Roel
2003 90 Td5 (2009-now)
Post #408549 17th Mar 2015 10:26pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
I have tried beads in my own tyres and several customers and they have never worked ! 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #408616 18th Mar 2015 10:03am
K9F
You must be doing something wrong! Many people have had success with them and the powder too. Or maybe your tyres had a heavy spot perhaps Question
Some do get on with them and some don't. You and your customers must have been unlucky. What ones did you use, tyre size and weight of beads in the tyres out of vested interest?
Offroading and large amounts of mud adhered to the tyres can affect them severely. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408619 18th Mar 2015 10:14am
smb
Thought I would share my experience.
Had a new set of 265/75r16 BfG Mud KM2's fitted to a set of RVS(Terrafirma) Beadlock wheels without the beadlock ring fitted so being used as a conventional wheel/tyre combo. I watched them balance them on the machine and was shocked to see that the wheels needed between 160-270gms each. They weren't damaged at all so didn't sound right, but the machine said it was right. Driven 3000miles with the most horrendous vibration right up to 70mph.
So, bought enough sets from Devon4x4 and set about fitting 150gms in each tyre and taking all the weights off. Then fitted the beadlock rings so now they are 265/75r16 BfG KM2 Muds set at 32psi on RVS Single Sided Beadlock rims with the Beadlock ring securing the outer edge of the tyre. As a single sided deadlock should be used.
Result: No vibration whatsoever and the 110 drives like a new one. Excellent product that does exactly what is said it does.
I think I will now take all the unsightly weights off my other car wheels and try the ones from Beadlock UK as they have an applicator that attached to the valve stem which will save me having to break the tyre of the rim.
Top and Bottom of it, they worked on mine. Thumbs Up As mentioned earlier on the thread, who is to say the balancing machines are accurate. Plus, how can you ensure the wheel has been put on the machine exactly right!
Post #426589 27th May 2015 9:33am
K9F
K9F wrote:
You must be doing something wrong! .......What ones did you use, tyre size and weight of beads in the tyres out of vested interest?
Never did get a response!
I have had mine on for a couple of months now. Initially when fitted I had a slight vibration at exactly 50mph only. The fitters had inflated them all to 36psi. Once I played around a bit with the pressures and reduced the fronts down to 32 and increased the rears slightly to 38 all now runs smoothly.
Post #426595 27th May 2015 9:51am
@ SMB a good fitter will know Thumbs Up cant speak for all
Post #426603 27th May 2015 10:43am
K9F
K9F wrote:
Ken from the forum also kindly offered to balance mine but time and distance precludes this. With a dedicated fitter/balancer anything is possible but they are I think in very short supply. Thumbs Up
Ken good tyre fitters I know now are like hen's teeth. I shall not go into too much detail but when I got my KM2's the walls of one tyre where stored had collapsed. To find a decent fitter that could spend a little time to get the tyre to bead on the rim took a round robin trip to three different places. The second blatantly couldn't be ar5ed to even discuss the issue.
Needless to say I know where to go in future! That was a very frustrating day! Most tyre fitters round here are grubby individuals who can't seem to think outside the box and are just robots with limited intent towards customer satisfaction and are clockwatching for their next tea break or job and knock. NOT ALL I have discovered.
Post #426604 27th May 2015 10:50am
Big floppy tyres are always fun particularly when you need to remount n rotate Thumbs Up an additional CEMB ER85 turned up today Mr. Green
Post #426605 27th May 2015 10:57am
K9F
If I'd have known about the issue I could have 'borrowed' a couple of vehicle ratchet straps from work and resolved the problem myself without leaving home perhaps? Never mind fitted now! Just for information.....You can only get two 305 tyres and two 16" Mach 5s in a new Mini with the seats down and to fit 5 tyres takes three flippin' trips! I wouldn't have faired any better in the 90!
Rolling with laughter Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #426607 27th May 2015 11:25am
smb
Very true. Unfortunately, like everything else nowadays it is very difficult to find someone close by that actually knows what they are doing. It seems that just because they have the latest equipment it doesn't mean they are going to get it right and lets face it, how many mechanics/technicians actually have 'true' skills???
Post #426610 27th May 2015 11:43am
Mechanics should be good
Tech's well nuff said
Quite funny we asked our BMW tech's when they last ground valves in answer a I don't understand
Have ever they polished and ported a Head rewound an alternator same look Rolling with laughter
And old Mechanic has a stethoscope a tech has Google Thumbs Up
Post #426619 27th May 2015 12:13pm
Page 2 of 3 <123>
