![]() | Home > Puma (Tdci) > Where do you put your Madman!? |
As it is panel mounted and in the most obvious place you don't want to fit it I think your options are limited.
http://shop.challenger4x4.com/mud-uk-land-...-941-p.asp With my Scangauge II I bought a 'Blendmount Kit' and mounted it above and on the rear view mirror well out of the way. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Jay Member Since: 23 Apr 2012 Location: Veneto Posts: 27 ![]() ![]() ![]() |
yes, I know, my options are limited.
the Blendmount Kit is a great idea, but not for EMS2 i think. Mud puma Pod is first choice, but over there I'd like to put my Garmin 176C. other options that i thought (another impossible crazy idea for my landy ![]() ![]() ![]() Click image to enlarge but 3D print costs too much for the moment. Is there any similar support on the market?? Jay |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 ![]() ![]() |
You can get a purpose made mounting kit for the EMS2 but I am not sure if that will help you decide where to put it.
Barbara |
already seen it
but it's only a preformed box anyway thanks for the suggestion Jay |
Ciao Jay
![]() Click image to enlarge more infos here http://www.defender2.net/forum/post201952.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Ciao Daniele...
Vista questa soluzione...ma li il nostro volante non ci fa vedere niente..è nascosto quel punto. Hello Daniele ... already View this solution ... but with our steering wheel we aren't be able to see anything ..it's blind corner Jay |
Does that mean "Read my first post you plonker!" In Italian?
No offence meant or implied Daniele. ![]() ![]() **EDIT** I work in the marine industry and note that the Madman EMS2 has a size of 60mm x 60mm. Do you have the option of removing the bezel and be left with a round gauge? If so have you considered a "boat gauge pod?" I threw in a diameter of 80mm and came up with the few below. Try a bit of 'Googling' down the marine route to see if anything is suitable or adaptable. ![]() Good luck. https://www.google.co.uk/search?q=80+mm+bo...p;tbm=isch If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
One day Ima go to New York to a bigga hotel. I tella the waitress I wanna two
![]() ![]() ![]() ![]() ![]() Later, I go to eat soma lunch at Drake Restaurant, the waitress bringa me a spoon, ana knife, but no fock. I tella her I wanna fock. She tellsa me everybody wanna fock. I tella her, you no understand, I wanna fock on the table. She say you better not fock on the table. You sonna Ma Bitch. I don't even know the lady and she call me a sonna Ma Bitch. So I go back to my room inna hotel, and there's no sheet on my bed. I calla the manager ana tell him I wanna sheet. He tells me to go to the toilet. So I say you no understand, I wanna sheet on the bed. He say you better not sheet on the bed, you sonna Ma Bitch. I don't even know the man ana he call me sonna Ma Bitch. I go to check out and the man at the desk he say peace to you. I say ![]() I go back to Italy!!! not censored http://www.manuscritto.it/maccheronismi.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
a nice 360mm dia or 380mm dia NEW steering wheel????? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Hi to all
I've found the perfect position for the Madman. For me is this: ![]() Click image to enlarge (3D planning) And this is the first prototype that need some adjustments ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I choose this solution becouse the device (any, not only the madman) is out of the steering wheel size, and during the driving must not move yourself to see the device. When I'll finish the bracket I'll cover it with some imitatione leather or plastideep. Jay |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2621 ![]() ![]() ![]() |
I just saw another option: replace the clock!
https://scontent.xx.fbcdn.net/hphotos-xpt1...e=56CF061B -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Naks, quite often the simplest of solutions are the best. I like that idea! ![]() Treat every day as if it is your last....one day you will be right!! |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Very nice Jay!
I am having the same question, and had previously thought to install as suggested by Daniele (and get a smaller steering wheel), but your solution is pretty neat... Are you planning to commercialize it? |
Thank you redline
I don't know, but if someone need the bracket or somthing else, I can realy think for comercialized it, with my other works. For the moment I finish this and then we'll see, if there is someone interested Jay |
