Home > Puma (Tdci) > Ecu calibration-software version
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
The other day i was playing with the nanocom and i observed that on my 2.4 puma the software version number is 7H12-12K532-HG and on my mates 2.4 puma reads 7H12-12K532-FDD.
Is there any newer version around for 2.4 pumas?
No significant problems on both defenders,whatever comes up is repaired-maintained by us,no dealers visits for a very long time..
Should we bother about the calibration etc?
Thanks.
Post #407231 13th Mar 2015 12:43pm
fatman
And one more question-for my 100th post- please..
My puma's injectors are more noisey-rattling than on my mate's puma.
Can i do injector learn and pump learn ONLY without updating-changing the current calibration version?
Thanks.
Post #407781 15th Mar 2015 3:52pm
Alive Tuning
The latest calibration version is FDE (in the case of your mates 110) so there's even an update for that! The difference between FDD and FDE is negligible, but the difference between the very old HG calibration and the latest CE/DE calibration is significant.
You can do the pump learn and pilot correction learn procedures on your existing calibration, no problem.
It might be worth you looking at the live data of your mates 110 and comparing them with your own, paying particular attention to the fuel rail pressure. A variance would suggest a fault with your VCV and so it would be a good idea to replace this, and then carry out the pump and pilot learn procedures.
Regards,
Gary.
Post #407862 15th Mar 2015 7:23pm
fatman
Thanks a lot!
Post #407975 16th Mar 2015 9:51am
Merlin
Is there an significant update for the V1 remap that you supplied?
Merlin
Post #408097 16th Mar 2015 3:38pm
fatman
Regards,
Gary.
Does anyone know what is the nomimal-optimal fuel rail pressure?
Thanks.
Post #408704 18th Mar 2015 3:26pm
fatman
I went for a short drive with the nanocom plugged,max fuel pressure reading was 123.56 but to what units is this measured,if MPa then its only getting up to 1235.6 bar????
Post #409029 19th Mar 2015 4:53pm
Fifth Horseman
Can't remember what the units are, but when I checked my old 2.4 (unknown calibration level but running ok) on the Nanocom, it showed a max of 158 and about 23 at idle.
Post #409056 19th Mar 2015 6:52pm
fatman
I also found this that matches your readings too! http://www.defender2.net/forum/topic24890.html
Thanks to Lorryman100 for the video,i'll make some more live data recording but it seems i am low on pressure - fuel not blood Laughing Laughing
Post #409194 20th Mar 2015 9:04am
