|  | Home > Technical > Unidentified object |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | I have no idea sorry. Heater control of some descript perhaps? What happens if you allow it to count down to zero.
      If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  12th Mar 2015 9:34am |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501      | Is it for checking your 0-60 time    2005 Td5 90 XS Steve | ||
|  12th Mar 2015 9:39am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | ^^^
 Only if the 649 depicted is hours and minutes......  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  12th Mar 2015 9:41am |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347      | Looks like a timer for a webasto type parking heater to me     Worth having a nose around your engine bay! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter  | ||
|  12th Mar 2015 9:48am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | yep - logo looks like Eberspacher - timer switch mini
   The centre looks like it is missing a pad:   Click image to enlarge This link might help identify if you have any other parts fitted: http://www.windowsmediapc.co.uk/t4/2007/06...ronic.html Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated   Last edited by Supacat on 12th Mar 2015 11:36am. Edited 4 times in total | ||
|  12th Mar 2015 11:18am |
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663      | Looks like a control unit from an early Espar D2/D4 maybe? | ||
|  12th Mar 2015 11:28am |
| JJ440 Member Since: 08 Nov 2013 Location: Geneva Posts: 51      | You guys were right! Eberspächer!
 Had no clue it had been sitting there all this time. Did a full service, changed the clutch master cylinder and replaced the drive belt without ever noticing it. The real joke is that I have been driving around dressed like an Eskimo all winter.   Click image to enlarge   Click image to enlarge Will let you know if it still works. | ||
|  12th Mar 2015 1:44pm |
| capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223      | If it works you'll be toasty. I ran a D4 in my boat a few years back - super piece of kit when it's working well, expensive parts and service | ||
|  12th Mar 2015 7:55pm |
| JJ440 Member Since: 08 Nov 2013 Location: Geneva Posts: 51      | Can't get it to work...right at the bottom of the to do list. | ||
|  14th Mar 2015 9:04pm |
| capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223      | The D5WS is a different beast to the D4 which I ran on my boat. Yours heats water (I think) and mine basically burned diesel to produce hot air.
 Good luck with getting it to work, loads of info on the Net, including YouTube | ||
|  15th Mar 2015 9:06am |
| Posting Rules
