![]() | Home > Puma (Tdci) > What's the relay in Battery compartment supply? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
Tow bar?
You got one fitted? As I don't think relay in battery box is standard, so must be an extra. Tow bar, winch, lights Andy |
Do you have an SVX front ?
If you've got a a grey lid 12S or a 13 pin socket it'll be for that.
.....or, if you've got a second battery fitted. ![]() |
MVS Member Since: 20 Sep 2014 Location: N Yorks Posts: 16 ![]() ![]() ![]() |
It'll be for the 13 pin towbar I had fitted then!
Presumably the power supply to fridge/charger when the engines running. Is the white/red the switched live to the rear socket? Thanks chaps |
