![]() | Home > Technical > 2014 2.2 oil consumption |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Can't comment on a Defender - But every new Transit I've checked via work [Exact same engine] has always seemed to have oil level on or even below minimum within a few thousand miles
![]() I'm not talking 2 or 3 vans here - Feckin hundreds of them ![]() |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Thanks very much. Looks like it's a case of "they all do that Sir."
I'll stop worrying and keep it topped up! |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I was told by my dealer that it would use 1 litre a 1000miles 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
First 20.000 kilometers never needed to top it up with a single drop. Stopped checking it on a regular basis since then.
Jake the dog Member Since: 02 Jan 2014 Location: Worcestershire Posts: 29 ![]() ![]() ![]() |
24000 miles in 14 months and not a drop of oil needed to be put in between the two services I've had since new. That's probably the kiss of death
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3673 ![]() ![]() ![]() |
13000 not used any but is a 2.4 DEFENDER 90 TDCI XS,
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Used less than 1/4 pint over the 12000 miles I have covered in the last 9 months
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
My 2013 Puma 110 has never used any oil between services, and that's in 45deg+ heat!
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
yep, there shouldn't be any oil used on the Puma engines, whether 2.4 or 2.2 --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Crawford Member Since: 23 Aug 2010 Location: Buckinghamshire Posts: 12 ![]() ![]() ![]() |
Well just to add to the mix. I've just done my first oil change at 1350 miles and only got 6 litres out and that included the oil from the filter. Filled it back up to the max on the dip stick and could only get 6 litres back in!
Only on a Landrover ![]() |
check the injectors studs Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Spookytooth Member Since: 19 Jan 2014 Location: Lincolnshire Posts: 202 ![]() ![]() ![]() |
Can only add that I posted a thread on here (last year) because I was worried that my 2.2 Defender (13 plate) was NOT using any oil and was concerned that water or something might be getting in. Consensus at the time was 2.2 does not using oil at any great rate
Thanks for all the replies. My dealer has asked me to monitor how much oil is being used and keep them informed. If it is excessive (and I must admit, I'm disappointed with it), I trust that the warranty will get it sorted out.
let us know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
