![]() | Home > My Defender > Td5 110DCPU |
Welcome Dan,
As mentioned in the link below that will give you a few pointers with regards to security if you do a forum search under 'layers' there are plenty of tips and hints regarding security. Nice looking truck. X-Eng gear lever lock as it's a TD5 rates quite highly. ![]() http://www.defender2.net/forum/topic33455.html?highlight=layers If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5997 ![]() ![]() |
Nice.
What make is the rear cover. Andy |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Lovely truck dan just what I would like as my next land rover
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
Very Very Nice
love the rear winch |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
will have to look out for you...Think I know where abouts you are.. We have a fair few driving round Tamuf ourselves. .A green 90 PC, a Bonnetti Grey 110 DC and a Silver 110 USW, all with OPO in the plates. Also drop in and see us down @ IRB , just after Villa training ground... Putting Dreams on Drives at JLR Solihull..
jk84 Member Since: 17 Feb 2015 Location: Wherever my Defender takes me... Posts: 720 ![]() ![]() ![]() |
Now that's a very manly truck
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Very Nice!
was going to look at that one when I just got my td5 double cab tuesday. Think you got a good deal there. ![]() |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
That does look very nice!! Congrats
dan_seed Member Since: 11 Mar 2015 Location: Tamworth Posts: 31 ![]() ![]() ![]() |
Thanks for all the comments guys.
Still getting to grips with everything. Have had the abs and tv light appear a few times...... So need to get to the bottom of that! Had some dodgy tyre pressures which I have now sorted.....seems to have made the issue better but still appeared after 1 incident of heavy breaking......confused! The canopy is the wolf canopy I believe. |
1. In the tub, in the standard position (do you still have the mounting stud & wheel plate?); or 2. In the tub, mounted along the wheel arch; or 3. On the rack, either tied down or using a rear door spare wheel fixing kit. |
Thanks supa.
Where is the standard position then? No mounting plate in mine. Well that I have noticed anyway! ![]() |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
There should be a fixing in the pick up bit under the window. With a threaded bar attached that goes through the middle of the wheel.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Cheers guys. Not spotted this but will check it out again tomorrow.
