Home > Off Topic > Question for the Builders
walfy
Currently in my garage I have an old plastic window. Which leaks like a sieve. It sits between two piers that are part of the wall. Between the edge of the window and the pier there is approx 6" of blockwork.
I have the chance of a nice double glazed window to replace it but need to open the gap up by 1 1/2" either side of the existing hole.
Is this feasable? Or is there a minimum amount of blockwork you have to have either side of a window aperture before a pier in the wall. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #407072 12th Mar 2015 10:35pm
JWL
As long as you have something across the top of the window opening to stop any bricks/blocks from resting on the actual window frame in the form of a lintel or are you up to the top plate that the roof is built onto? If so get the disc cutter out and open the aperture up and slide the new window in. What's inbetween the piers is just infill by the sound of it so it could be a doorway, patio doors or a wooden panel as it sounds like the roof is supported by the piers.
Post #407103 13th Mar 2015 12:15am
walfy
It's a concrete block wall. The garage is about 2m longer than my 90 which has taken up residence inside the garage. Along that length of wall I have 2 piers built into the wall. So there is no huge span between piers and there is a concrete lintel over the window and then 2 courses of red bricks and then the wall plate. So no huge weight above and it would be easy to put a bigger lintel in if required.
Looks like I'm going to get the disc cutter out. Happy days. Can't beat a bit of mess and noise to keep the neighbours happy
Many thanks Thumbs Up Thumbs Up 110 D250 SE HT
110 USW SOLD
Post #407146 13th Mar 2015 9:24am
farmer giles
the general length of lintel bearing is 150mm at each end; but this can be reduced down to 100mm if there is minimal loading above, so you might not need to change the lintel.
Post #407153 13th Mar 2015 9:33am
walfy
Fair point. But in the near future I want to raise the height of the roof so my110 with rack and tent fits inside. So would need to go up 2 or 3 courses of blocks. Will have a measure tonight and see exactly what I have. Thumbs Up 110 D250 SE HT
110 USW SOLD
Post #407159 13th Mar 2015 9:38am
landy andy
Post a pic up if possible.
Sounds doable but would be a pain to remove such a small amount.
Is the wall single skin of bricks/blocks?
Do you have to remove material from both sides? It's twice the work.
Have you priced a new double glazed unit? They aren't costly.
Andy
Post #407166 13th Mar 2015 9:52am
walfy
as you can see the wooden frame has taken a battering this winter. I have been offered a take out window that will fill the gap for £30. Seems people round by my parents have more money than sense.
 110 D250 SE HT
110 USW SOLD
Post #407336 13th Mar 2015 6:59pm
JWL
Personally I'd disc cut the right hand side and probably take the bricks out above the lintel, loosen the lintel out and recentre it over the window. Replace the bricks and job done leaving it ready to build higher at that later date
Post #407405 13th Mar 2015 11:24pm
walfy
Now I'm happy that there is no restriction on cutting into the wall.
I think I'll do as you suggest and cut into 1 side. And then play with the lintel. 110 D250 SE HT
110 USW SOLD
Post #407407 13th Mar 2015 11:32pm
