Home > Wheels & Tyres > Military Blindos
Page 2 of 2 <12
familymad
Mike_B wrote:
They're the same wheel. Blindo used to be the name referring to the F-15 Texh which was the only one the MOD used. 15 spoke design with steel cups inserted into the bolt holes. There's a YouTube vid of the factory somewhere.
Ricardo chose the Blindo because of it's strength. The other useful feature was that if the vehicle hit an ied, the wheel would shatter instead of turning in shrapnel like the HD wolf wheels would.
The point about the run flats isn't a major problem as the vehicles that were equipped with run flats had special plastic inserts fitted too. The looked like a big plastic bolt-together polo mint, in primer green. Ex military wheels will have been battered by a million miles in crappy conditions though..
N.O.S. Military ones would be a good idea, but you don't find them just knocking about. They will have been bought as batches for projects like RWMIK and there will not have been surplus.
There's a place in S wales selling some at the moment from a load of military land rovers. They're the Evo Corse version. New take off, in drab olive green.
Which company? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #403333 1st Mar 2015 2:18pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Tacticall S&C
Barry
03309003867
He had a load of green Dakar wheels in stock last week. Plus the run flat rings if you're interested in putting an extra 15kg inside each wheel!
Post #403340 1st Mar 2015 2:29pm
Don't forget that the Evo Dakars are different to the Blindos, have a different spoke pattern, and a lower load rating. They are however similar and I have seen military vehicles with a mix of the two types.
Post #403350 1st Mar 2015 3:14pm
Sand Rover
Scotland 1998 Defender 110 300 Tdi HT Coniston Green
Mike_B wrote:
Tacticall S&C
Barry
03309003867
tried calling that number but its says no such number .... can you check if that's the correct number thanks
Post #404140 3rd Mar 2015 5:24pm
Mike_B
You have a PM
Post #404154 3rd Mar 2015 5:53pm
DSC-off wrote:
AFAIK, the Blindos were fitted during upgrades to the WMIKs, for increased load. Not Pulse or Snatch.
The work wasn't done by LR, and they didn't supply the wheels.
Could be wrong, but seem to recall it was Ricardo that did the work.
Silverline is probably your only chance of getting any new ones.
Yes, it was Ricardo that did the RWMIK+ upgrade.
Also did the VIXEN upgrade to Snatch, they had Blindos too. (And a 2.8 engine with auto box)
Ricardo were showing this Defender at the 2009 DVD Show as their bid for the "Re-life of the LandRover utility fleet"
Post #406894 12th Mar 2015 1:28pm
Interesting - looks like Blindos on the ground and a Dakar as the spare.
Post #406908 12th Mar 2015 2:19pm
I keep looking but can't any difference - what are the differentiating features?
Post #406957 12th Mar 2015 5:15pm
The most noticeable difference is the number and spacing of the spokes.
The Dakar has twelve unevenly spaced (alternately small and large gaps).
The Blndo has fifteen evenly spaced.
Simples! Thumbs Up
Post #406983 12th Mar 2015 6:04pm
Thanks - I'm going to have to count (in a Rainman fashion) spokes on every Blindo/Dakar type wheel I see from now on...
Post #406985 12th Mar 2015 6:09pm
It's easier just to go on the spacing: even = Blindo, uneven = Dakar.
Post #406986 12th Mar 2015 6:14pm
Ah - I get my life back Razz Thumbs Up
Post #406991 12th Mar 2015 6:21pm
Page 2 of 2 <12
